bose/infinity/mach
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote"> but I don't see why not. If it sounds like garbage, try hooking up a LOC, or a "premium sound interface"... </TD></TR></TABLE>Ditto the above.
94
94
You will need to bypass the factory amp first then you can hook up any aftermarket amp to the speakers. But most of the time, those factory speakers wont take much of a beating
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid-Performance.com »</TD></TR><TR><TD CLASS="quote">You will need to bypass the factory amp first then you can hook up any aftermarket amp to the speakers. But most of the time, those factory speakers wont take much of a beating </TD></TR></TABLE>It's for a sub...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda95civic »</TD></TR><TR><TD CLASS="quote">can you run a sub </TD></TR></TABLE>
94
94
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
make sure you grab the lowpass side of the signal, Not the highpass. It would sound alot better, I had this problem in the new g35.
just hook the line out converter to the speakers before the amplifier (if I am not mistaken) then use the low pass filter on your amp - i hope you have one - to tune out voices. I recommed setting it on 80Hz. MAKE SURE you are setting a low pass not high pass filter. You can tell because if you hear voices in your sub then you are running over 80hz
