bose/infinity/mach
Old Jun 26, 2006 | 11:56 AM
honda95civic's Avatar
Default bose/infinity/mach
can you run a sub high level with factory bose and infinity systems...
cars such as rsx and jeep grand cherokee
Old Jun 26, 2006 | 12:07 PM
B18C_EJ8's Avatar
Never tried it, but I don't see why not. If it sounds like garbage, try hooking up a LOC, or a "premium sound iterface"...
Old Jun 26, 2006 | 12:31 PM
fcm's Avatar
fcm
Old Fart
Default Re: bose/infinity/mach (honda95civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote"> but I don't see why not. If it sounds like garbage, try hooking up a LOC, or a "premium sound interface"... </TD></TR></TABLE>Ditto the above. 94
Old Jun 27, 2006 | 06:01 AM
VisualAutoMotoring's Avatar
You will need to bypass the factory amp first then you can hook up any aftermarket amp to the speakers. But most of the time, those factory speakers wont take much of a beating
Old Jun 27, 2006 | 07:22 AM
fcm's Avatar
fcm
Old Fart
Default Re: bose/infinity/mach (Hybrid-Performance.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid-Performance.com &raquo;</TD></TR><TR><TD CLASS="quote">You will need to bypass the factory amp first then you can hook up any aftermarket amp to the speakers. But most of the time, those factory speakers wont take much of a beating </TD></TR></TABLE>It's for a sub...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda95civic &raquo;</TD></TR><TR><TD CLASS="quote">can you run a sub </TD></TR></TABLE> 94
Old Jun 27, 2006 | 10:19 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
make sure you grab the lowpass side of the signal, Not the highpass. It would sound alot better, I had this problem in the new g35.
Old Jun 27, 2006 | 12:15 PM
Default Re: (wrx-killer-Sti eater)
when you say lowpass.. do you mean from the output of the factory amp for afactory sub??
Old Jun 27, 2006 | 01:55 PM
Default Re: (honda95civic)
as long as it not the tweeter.
Old Jun 27, 2006 | 05:06 PM
CFactor's Avatar
just hook the line out converter to the speakers before the amplifier (if I am not mistaken) then use the low pass filter on your amp - i hope you have one - to tune out voices. I recommed setting it on 80Hz. MAKE SURE you are setting a low pass not high pass filter. You can tell because if you hear voices in your sub then you are running over 80hz
skrewdriver88
Audio / Security / Video
Aug 24, 2004 08:21 PM
kevinm1981
17
Jul 23, 2004 12:45 PM
jordan-boxer
15
May 8, 2004 06:03 PM
Linh.
30
Mar 9, 2004 05:57 PM
hugh_jazz_sponer
18
Oct 6, 2003 08:31 AM
