car wont start
Old Jun 23, 2006 | 08:08 AM
i hate rice's Avatar
Default car wont start
ok so i blew my clutch,
and completely blew it.
i put a new clutch in
and now my car wont start.
it'll "start" but it barly start and its just sputtering and cuts off within a few seconds no matter how much gas i give it,
what would cause my car to do this?
map sensor? TPS?
all help is appreciated
Old Jun 23, 2006 | 08:12 AM
4thgenhtch's Avatar
Default Re: car wont start (i hate rice)
Did you take any grounds off the motor when you did the clutch? Double check them all...
Throwing any codes?
Old Jun 23, 2006 | 09:04 AM
Default Re: car wont start (4thgenhtch)
all the grounds are good,
and its been throwing codes ever since i put the motor in, and no matter what i do the codes remain, i even took it to a shop and its still throwing codes, so i dont even bother looking at my ecu anymore to check for codes.
Old Jun 23, 2006 | 11:49 AM
4thgenhtch's Avatar
how is your fuel pressure? no external coils or ignition amps?
Old Jun 23, 2006 | 12:00 PM
Immanuel's Avatar
check the ground to your starter.
Old Jun 23, 2006 | 01:34 PM
Default Re: car wont start (1.6 DOHC ED9)
the ground wires are ALL fine.
Modified by i hate rice at 3:59 PM 6/23/2006
Old Jun 23, 2006 | 03:01 PM
so i changed the map sensor. no luck i changed my ecu, and its not throwing any codes now.... the battery died and i jumped it and then it seems to be running fine.
but now its not running fine..
could it be my alternator causing my car not to rev up?
Old Jun 23, 2006 | 03:04 PM
justseeingifitistaken's Avatar
sounds crazy but when i changed my clutch i took off my dizzy and i had accidentally changed my timing drastically. just an idea.
Old Jun 23, 2006 | 03:08 PM
90JDMEF8's Avatar
check that starter grounds and power and make sure its tight enough... that will make a big difference...
Old Jun 23, 2006 | 03:47 PM
Default Re: car wont start (90JDMEF8)
its all on tight, and when i changed my clutch i didnt touch the dizzy, and when the clutch went out the timing jumped. and i readjusted it with a tool from napa and my timing has never looked so good.
its gotta be something i just jumped my car and let it idle till it damn near overheated and the battery is still dead. but even when i jumped it and had the cables hooked to my brothers car it still wasnt running right
Old Jun 23, 2006 | 04:36 PM
http://s14.photobucket.com/alb...e.flv
ok that's normally how it accelerates
http://s14.photobucket.com/alb...I.flv
that's how its doing now....
what can cause this,
that's what i wanna know
Old Jun 23, 2006 | 05:31 PM
bump
Old Jun 23, 2006 | 06:09 PM
bump again.
someone has to atleast have a guess
im getting tired of sitting at home cause i dont have a car to go anywhere
someone take a ******* stab it.
at least it'll give me something to do
cause as of right now i dont ever know where to begin,
and like i said im going crazy cause im home on a friday
just take a ******* guess!!!!!!!!
Old Jun 23, 2006 | 06:31 PM
crxblues's Avatar
umm charge your battery first
Old Jun 23, 2006 | 08:53 PM
Default Re: car wont start (crxblues)
the batt is new, i just went and got it tested and it was the alt... i changed that but its still not reving up very good which i think is my TPS which i will change when i have day light.
its good damn thing i have a honda junk yard in my back yard
Old Jun 25, 2006 | 08:29 AM
ok that wasnt it.
and i have completely ran out of any ideas of what it could be
ive checked all the grounds, and how tight they were,
ive checked my whole wiring harness, and the wires going out of the ECU.
the timing is on point
ive changed the map.tps and cps, and the dizzy.
and it still wont run right.
what in gods motha ******* name can cuase a car to run like that?
Old Jun 25, 2006 | 12:21 PM
bump
Old Jun 25, 2006 | 12:25 PM
SiR Inspired ED7's Avatar
It sounds like your timing is retarded to me
Old Jun 25, 2006 | 12:48 PM
reynardmauricio's Avatar
Default Re: car wont start (SiR Inspired ED7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Inspired ED7 &raquo;</TD></TR><TR><TD CLASS="quote">It sounds like your timing is retarded to me </TD></TR></TABLE>
what he said or possibly the throttle cable?...
Old Jun 25, 2006 | 12:49 PM
Default Re: car wont start (reynardmauricio)
most like its the dizzy... just make sure its TDC.
crick_james
Oct 7, 2008 07:57 PM
RC_Benjamin
Oct 29, 2005 03:35 PM
scorched0
Jun 27, 2004 04:40 PM
DragInteg
Apr 21, 2004 12:09 PM
NX_LS
Jan 15, 2003 08:28 PM
