Got Tuned Today overheating now
Old Jun 22, 2006 | 04:24 PM
94integragsr's Avatar
Banned
Default Got Tuned Today overheating now
ok i got tuned today and puled 302hp 225ftpt i noticed though that the car gets hot real quick any ideas? i havent let it get all the way hot yet what should i do
Old Jun 22, 2006 | 04:30 PM
A.E Motoring's Avatar
Default Re: Got Tuned Today overheating now (94integragsr)
could be thermostat or thermo switch, fan kicking on?
Old Jun 22, 2006 | 05:02 PM
back again's Avatar
Default Re: Got Tuned Today overheating now (SPNFEDEH)
Start with the simple stuff. Thermostat, kinked hoses, fan fuse, etc.
Old Jun 22, 2006 | 06:01 PM
Banned
Default Re: Got Tuned Today overheating now (back again)
fan kicks on
Old Jun 22, 2006 | 06:03 PM
Danny_EJ's Avatar
low coolant? air pockets?
Old Jun 22, 2006 | 06:11 PM
jdmbb6-t's Avatar
This happen to me a couple of days ago.... when I would stop at a light or anywhere for that matter my car would get hot. I noticed when I turned my car off i could hear a hissing sound. I looked under the hood and it was the top radiator hose... it had a small hole in it and it was leaking all the fluid out. I changed the hose snaped the clamps back on, no problems since then. Im not saying this is your problem, but just something you should look at.
Old Jun 22, 2006 | 08:47 PM
raceACCORDingly's Avatar
bleed air and add some water wetter or a couple drops of hand/dish soap.
Old Jun 22, 2006 | 09:22 PM
TypeSLO's Avatar
Default Re: (raceACCORDingly)
are you losing any coolant? then look for a leak. if you can't find a leak, maybe bad head gasket. if you're not leaking, check thermostat, fan switch, etc. some people wire the fan to run all the time. i'd flush it out and make sure there are no air bubbles in it.
Old Jun 22, 2006 | 10:36 PM
qfast817's Avatar
Default Re: (TypeSLO)
do you have a open down pipe? or a dump tube close to the radator?
Old Jun 23, 2006 | 02:34 AM
Banned
Default Re: (qfast817)
i will try moving the dumptube it is kinda close
simplegreenmachine
13
Dec 12, 2009 04:07 PM
vlude99
Jul 30, 2009 05:58 PM
twenty
Jul 21, 2005 08:36 AM
vinuneuro
Jun 22, 2005 10:16 PM
made in JAPAN
Oct 15, 2003 06:46 AM
