my car is bogging down and vtec is not kicking in
Old Jun 20, 2006 | 10:03 AM
97bb6preyLude's Avatar
Default my car is bogging down and vtec is not kicking in
i have 97 prelude and my car bumps a little b 4 3ks and then boggs down and vtec dont work help me out plz
Old Jun 20, 2006 | 10:48 AM
bluedlude's Avatar
Default Re: my car is bogging down and vtec is not kicking in (97bb6preyLude)
change your oil and filter.... sounds like low oil pressure which could be from a number of things, but thats the first that comes to mind.
Old Jun 20, 2006 | 01:02 PM
Default Re: my car is bogging down and vtec is not kicking in (bluedlude)
i changed my oil and oil filter same prob what can you do about low oil pressure
Old Jun 20, 2006 | 01:11 PM
MrLude1's Avatar
Sounds like a fuel/spark issue to me....Can you get into the upper RPM range, if not your in limp mode....check your spark & fuel pressure too. If they're fine, have an auto parts store do a compression check on each cylinder. Check your VTEC oil-pressure switch....it's under your distributer on the block w/a green plastic plug, maybe it could be loose or bad wires? Chime in if any of these works.
Modified by MrLude1 at 2:26 PM 6/20/2006
Old Jun 20, 2006 | 01:14 PM
vietdragontekx's Avatar
see if your fuel line is crimp(the one going from the fuel rail to the fuel filter).
Old Jun 20, 2006 | 02:21 PM
bluedlude's Avatar
Default Re: my car is bogging down and vtec is not kicking in (vietdragontekx)
so im trying to think of a way you can determine if its a fuel issue, and all i can come up w/ is pull the hose going from the fuel pressure regulator to the IM and test her out to see if it made a slight change or none at all. if it did, it might be your fuel. if it doesnt it probably is an oil pressure or spark problem.
Old Jun 20, 2006 | 04:26 PM
vtec fan's Avatar
I have the same problem, bogging down between 2k and 3K after some internet research my conclusion, o2 sensor going.
Old Jun 21, 2006 | 11:24 AM
Default Re: (vtec fan)
Thanks for the help i will go check all of these things
Old Jun 21, 2006 | 11:26 AM
98vtec's Avatar
moderator emeritus
Default Re: (97bb6preyLude)
https://honda-tech.com/zerothread?id=830163
Old Jun 21, 2006 | 11:33 AM
the green plug was not loose how do i check 4 bad wires
Team PHATBOYZ
Jun 6, 2008 05:09 PM
del Slo SiR
47
Jan 6, 2007 07:19 PM
THugluv423
Jan 11, 2006 01:30 PM
VtecDA9
Jul 8, 2003 06:36 PM
Witty
May 28, 2003 06:10 AM
