Car bogs at vtec all of a sudden?
Old Jul 5, 2003 | 11:18 PM
VtecDA9's Avatar
Default Car bogs at vtec all of a sudden?
The car was warm when driving, and recently the car bogs slightly at vtec, then hesitates to gain power for a few hundred rpm after that... Any ideas? The motor is a fresh rebuild 1500 miles and ran very strong until recently... other problems, car runs shittier than normal on a low tank of gas. Like I said for like over 1000 mioles, the car was smashing out... moderatley driven though???
Old Jul 6, 2003 | 07:06 AM
JDMHEIM's Avatar
Default Re: Car bogs at vtec all of a sudden? (VtecDA9)
Could be something minor before panicking, check and see if your vtec solenoid filter is clogged, if oil pressure is low vtec is affected. Also check your fuel filter and pcv valve. Also make sure your ls/vtec hardware lines are tightly fixed to your motor, and not leaking.
good luck.
94 civic cx
jdm b18c
soon to be supercharged
Old Jul 7, 2003 | 05:01 PM
VtecDA9's Avatar
Default Re: Car bogs at vtec all of a sudden? (JDMHEIM)
The PCV valve is new, but what would I check on that anyhow. Is there any way to check the fuel filter w/out replacing it? What does a bad fuel filter look like? The motor isn't leaking anything...
Old Jul 7, 2003 | 05:11 PM
granada_sun's Avatar
does the engine have plenty of oil?
i mean, thats what activates vtec is oil pressure.....
Old Jul 8, 2003 | 11:55 AM
preluder's Avatar
Default Re: (granada_sun)
yeah and start pullin codes maybe your car caught something and went into limp mode to warn you .
Old Jul 8, 2003 | 06:36 PM
VtecDA9's Avatar
Default Re: (preluder)
Not sure what the problem was, bu tI switched out my sk2 chip 4800vtec to the vision 4500vtec engagement... checked all wires/fittings and ground as well and the car ran smoother and vtec engaged smoother. Not sure what did it, but it's running smoother... now I just need to fix the clutch... If it'snot one thign it's another.
thanhzz
Jul 21, 2011 10:32 PM
AP_TWO
Dec 26, 2005 11:20 PM
l2yanE
Sep 27, 2005 06:39 AM
E46Kid
Sep 10, 2005 12:17 AM
DC2point0
Aug 30, 2003 07:39 AM
