Deltagate
Old Apr 16, 2002 | 10:46 PM
SlowB16's Avatar
Default Deltagate
How far do you guys screw the screw into the wastegate. Mine is showing about 1/2 inch of thread. I have no idea where an ideal spot is.
Old Apr 16, 2002 | 11:25 PM
echo999's Avatar
New User
Default Re: Deltagate (SlowB16)
The further screwed IN, the more boost it will hold.
I initially unscrewed it as far as it would go. Better to get a boost
gauge to see what you're boosting, rather than guess.
Old Apr 17, 2002 | 05:12 AM
DragII's Avatar
Default Re: Deltagate (echo999)
I squeezed like 9psi out of my 7psi spring by tightening it way down there.
Old Apr 17, 2002 | 08:49 AM
teg2snbtrbd's Avatar
Default Re: Deltagate (SuperDragII)
currently my boost gauge isn't going over 6 psi. If I tighten the wastegate spring, would that help me get to 7psi? Trying to figure out whey I am not hitting full boost. This sounded easier to do first to see if this is the problem before I look to see if I have any leaks.
areyouasian
Nov 20, 2009 08:14 PM
SOHC_MShue
Mar 14, 2005 03:00 PM
mattcalica
Jan 17, 2004 02:49 PM
Nextelbuddy
Aug 25, 2003 01:56 PM
Fatty_1775
Oct 20, 2002 03:08 AM
