speedo problems
Old Jun 11, 2006 | 07:40 PM
importwarriorsi's Avatar
Default speedo problems
I am have speedometer problems.It is only the middle one it tends to quit every now and then.The speed and odometer. It does the ficker motion a time or two.I pulled the pod out and check all the wires they where pluged in well so no lose connections there.So any suggestions of what it may be could sure be a big help here.Thanks guys for all your help in this matter.
Old Jun 11, 2006 | 07:43 PM
EX-T's Avatar
Default Re: speedo problems (importwarriorsi)
What year car is it?
Old Jun 11, 2006 | 07:45 PM
JDM-EJ1's Avatar
Default Re: speedo problems (EX-T)
I would recommend checking and cleaning your VSS sensor.
Old Jun 11, 2006 | 07:46 PM
Sorry it a 94 civic coupe;where is the VSS sensor?
Old Jun 11, 2006 | 07:47 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importwarriorsi &raquo;</TD></TR><TR><TD CLASS="quote">Sorry it a 94 civic coupe;where is the VSS sensor?</TD></TR></TABLE>
It's located on the backside of your transmission and is held inplace by one 10mm bolt.
Old Jun 11, 2006 | 08:04 PM
Default Re: speedo problems (JDM-EJ1)
Hey thanks ill be sure to check that out.
Old Jun 11, 2006 | 08:05 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importwarriorsi &raquo;</TD></TR><TR><TD CLASS="quote">Hey thanks ill be sure to check that out. </TD></TR></TABLE>
99% of the time this corrects the problem.
Old Jun 11, 2006 | 08:38 PM
fmrprojects's Avatar
probably a loose connection at the VSS sensor
MOST
Mar 1, 2007 10:24 AM
hspoon
Aug 30, 2006 07:52 PM
iblingidawg
Dec 17, 2005 11:18 AM
unknown0001
Feb 28, 2005 02:43 PM
degooser
13
Aug 18, 2003 10:57 PM
