snapping axles in a launch?
ok so here's the problem, I snapped both of my axles lately, nd they both happened when I launched the car, now I dont launch it very high just between 5800-6100 so that way it doesnt bog out...so my question is, am I launching it right? or do I just need more durable axles? now before you guys say stop slipping the clutch im not im actually dumping it...so Im just trying to figure out the problem, or what you guys would recommend?
The axles are cheaper than a rear end, one of the two are going to break. I guess you lucked out. If you get stronger axles, all that stress is going to send your rear end to hell.
thats just the thing the first time the left axle broke, I had launched it at about 7-8x nd it snapped right there in the middle of the street....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap1_driver »</TD></TR><TR><TD CLASS="quote">thats just the thing the first time the left axle broke, I had launched it at about 7-8x nd it snapped right there in the middle of the street....</TD></TR></TABLE>
hooray for 8k rpm launches on the street.
Now that sounds like fun.
well if you broke two its probably your technique, not two deffective axles...to answer ur question, sounds like you should practice at a lower rpm...if ur asking us on here about tips for launching, then u dont belong dropping the clutch at 8k. sounds like u would be better off taping a brick to ur gas pedal and see what happens.
the stock s wasnt built with parts designed to launch under full throttle like ur doing, did u upgrade ur clutch or anything at all? or do u just like breaking expensive parts that require lots of labor?
when do dump the clutch i hope not at the launch because that could be your problem . My ap1 never had a problem at launch and i launch 5,800,so try not dumping on gear one see if that help you out .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap1_s2k »</TD></TR><TR><TD CLASS="quote">when do dump the clutch i hope not at the launch because that could be your problem . My ap1 never had a problem at launch and i launch 5,800,so try not dumping on gear one see if that help you out .</TD></TR></TABLE>
holy crap
holy crap
Yet another S heading towards the shytter.
^^ i've never had a problem so i'll keep on doing it and plus i have good times from it . Whats wrong with the dumping gotta have ***** sometimes!!!!
best time 1/4 13.8
best time 1/4 13.8
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap1_s2k »</TD></TR><TR><TD CLASS="quote">^^ i've never had a problem so i'll keep on doing it and plus i have good times from it . Whats wrong with the dumping gotta have ***** sometimes!!!!
best time 1/4 13.8</TD></TR></TABLE>
if u never have a problem, then why are u on here posting a topic about busting not one but 2 axles, and if u slip the clutch u wont have the harsh instant torque pressure that breaks parts. s2k is not a drag car, u want to drive it that way fine but upgrade the parts to ones that can withstand the pressure u r putting them through...
and the upgrade comment is right...if u put in tougher axles u will be putting even more pressure on the rear end, so then u upgrade that, then ur putting a lot of pressure on the driveshaft, so that breaks, then by the time uve busted all those parts ur tranny is gonna be pretty messed up, hence drag racing competitively is so expensive, u dont just put a 600hp motor into a stock car and kick ***, u need to build a car meant to handle the power u put in it, and ur driving style.
best time 1/4 13.8</TD></TR></TABLE>if u never have a problem, then why are u on here posting a topic about busting not one but 2 axles, and if u slip the clutch u wont have the harsh instant torque pressure that breaks parts. s2k is not a drag car, u want to drive it that way fine but upgrade the parts to ones that can withstand the pressure u r putting them through...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt »</TD></TR><TR><TD CLASS="quote">Reading > you.
It's two different noobs. Try again.</TD></TR></TABLE>
I launch my 02 S at 8200 Every weekend at that track the car has 80000 miles on it and my axles are fine. The key to launching a car at the track is to preload the clutch. Basically hold the clutch right at engagement "DO NOT SIDE STEP THE CLUTCH" If you hold the clutch right at engagement there is much less shock sent through the driveline.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt »</TD></TR><TR><TD CLASS="quote">One is ap1_driver, the other is ap1_s2k. Both noobs, similar names.
Yea I said it, bring it on!</TD></TR></TABLE>
ahha your on a roll!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prr1 »</TD></TR><TR><TD CLASS="quote">I launch my 02 S at 8200 Every weekend at that track the car has 80000 miles on it and my axles are fine. The key to launching a car at the track is to preload the clutch. Basically hold the clutch right at engagement "DO NOT SIDE STEP THE CLUTCH" If you hold the clutch right at engagement there is much less shock sent through the driveline. </TD></TR></TABLE>
This one's got something, ladies and genitals.
VDM_DC2
Suspension & Brakes
11
Oct 28, 2009 12:28 PM
turboman
Feb 20, 2006 11:40 PM
