Honda S2000 Honda S2000
snapping axles in a launch?
Old Jun 9, 2006 | 10:40 AM
ap1_driver's Avatar
Default snapping axles in a launch?
ok so here's the problem, I snapped both of my axles lately, nd they both happened when I launched the car, now I dont launch it very high just between 5800-6100 so that way it doesnt bog out...so my question is, am I launching it right? or do I just need more durable axles? now before you guys say stop slipping the clutch im not im actually dumping it...so Im just trying to figure out the problem, or what you guys would recommend?
Old Jun 9, 2006 | 11:43 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: snapping axles in a launch? (ap1_driver)
The axles are cheaper than a rear end, one of the two are going to break. I guess you lucked out. If you get stronger axles, all that stress is going to send your rear end to hell.
Old Jun 9, 2006 | 12:31 PM
Nishant's Avatar
Your launching techniques needs work. There are people launching at 7500-8k rpm's and not breaking axle's or diff's
Old Jun 9, 2006 | 01:02 PM
ap1_driver's Avatar
Default Re: snapping axles in a launch? (Nishant)
thats just the thing the first time the left axle broke, I had launched it at about 7-8x nd it snapped right there in the middle of the street....
Old Jun 10, 2006 | 07:59 AM
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap1_driver &raquo;</TD></TR><TR><TD CLASS="quote">thats just the thing the first time the left axle broke, I had launched it at about 7-8x nd it snapped right there in the middle of the street....</TD></TR></TABLE>
hooray for 8k rpm launches on the street.
Old Jun 10, 2006 | 10:37 AM
* B A N N E D *
Now that sounds like fun.
Old Jun 10, 2006 | 10:53 AM
mykcuz's Avatar
well if you broke two its probably your technique, not two deffective axles...to answer ur question, sounds like you should practice at a lower rpm...if ur asking us on here about tips for launching, then u dont belong dropping the clutch at 8k. sounds like u would be better off taping a brick to ur gas pedal and see what happens.
the stock s wasnt built with parts designed to launch under full throttle like ur doing, did u upgrade ur clutch or anything at all? or do u just like breaking expensive parts that require lots of labor?
Old Jun 12, 2006 | 08:03 AM
ap1_s2k's Avatar
Default Re: snapping axles in a launch? (mykcuz)
when do dump the clutch i hope not at the launch because that could be your problem . My ap1 never had a problem at launch and i launch 5,800,so try not dumping on gear one see if that help you out .
Old Jun 12, 2006 | 09:30 AM
98by911's Avatar
Default Re: snapping axles in a launch? (ap1_s2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap1_s2k &raquo;</TD></TR><TR><TD CLASS="quote">when do dump the clutch i hope not at the launch because that could be your problem . My ap1 never had a problem at launch and i launch 5,800,so try not dumping on gear one see if that help you out .</TD></TR></TABLE>
holy crap ????
Old Jun 12, 2006 | 09:55 AM
* B A N N E D *
Yet another S heading towards the shytter.
Old Jun 12, 2006 | 10:36 AM
ap1_s2k's Avatar
Default Re: snapping axles in a launch? (FR-MOB: Projekt)
^^ i've never had a problem so i'll keep on doing it and plus i have good times from it . Whats wrong with the dumping gotta have ***** sometimes!!!! best time 1/4 13.8
Old Jun 12, 2006 | 10:40 AM
* B A N N E D *
So how many times have you launched that car?
Old Jun 12, 2006 | 03:52 PM
mykcuz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap1_s2k &raquo;</TD></TR><TR><TD CLASS="quote">^^ i've never had a problem so i'll keep on doing it and plus i have good times from it . Whats wrong with the dumping gotta have ***** sometimes!!!! best time 1/4 13.8</TD></TR></TABLE>
if u never have a problem, then why are u on here posting a topic about busting not one but 2 axles, and if u slip the clutch u wont have the harsh instant torque pressure that breaks parts. s2k is not a drag car, u want to drive it that way fine but upgrade the parts to ones that can withstand the pressure u r putting them through...
and the upgrade comment is right...if u put in tougher axles u will be putting even more pressure on the rear end, so then u upgrade that, then ur putting a lot of pressure on the driveshaft, so that breaks, then by the time uve busted all those parts ur tranny is gonna be pretty messed up, hence drag racing competitively is so expensive, u dont just put a 600hp motor into a stock car and kick ***, u need to build a car meant to handle the power u put in it, and ur driving style.
Old Jun 12, 2006 | 04:01 PM
* B A N N E D *
Reading &gt; you.
It's two different noobs. Try again.
Old Jun 12, 2006 | 07:46 PM
mykcuz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Reading &gt; you.
It's two different noobs. Try again.</TD></TR></TABLE>
Old Jun 12, 2006 | 07:47 PM
* B A N N E D *
One is ap1_driver, the other is ap1_s2k. Both noobs, similar names.
Yea I said it, bring it on!
Old Jun 13, 2006 | 05:34 AM
prr1's Avatar
I launch my 02 S at 8200 Every weekend at that track the car has 80000 miles on it and my axles are fine. The key to launching a car at the track is to preload the clutch. Basically hold the clutch right at engagement "DO NOT SIDE STEP THE CLUTCH" If you hold the clutch right at engagement there is much less shock sent through the driveline.
Old Jun 13, 2006 | 08:15 AM
JDM knowledge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">One is ap1_driver, the other is ap1_s2k. Both noobs, similar names.
Yea I said it, bring it on!</TD></TR></TABLE>
ahha your on a roll!!!
Old Jun 13, 2006 | 09:12 AM
* B A N N E D *
Default Re: (prr1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prr1 &raquo;</TD></TR><TR><TD CLASS="quote">I launch my 02 S at 8200 Every weekend at that track the car has 80000 miles on it and my axles are fine. The key to launching a car at the track is to preload the clutch. Basically hold the clutch right at engagement "DO NOT SIDE STEP THE CLUTCH" If you hold the clutch right at engagement there is much less shock sent through the driveline. </TD></TR></TABLE>
This one's got something, ladies and genitals.
VDM_DC2
Suspension & Brakes
11
Oct 28, 2009 12:28 PM
mcgee*
Jun 5, 2006 07:42 AM
turboman
Feb 20, 2006 11:40 PM
jerzeytib
Oct 22, 2003 08:49 PM
hybrid901
May 23, 2002 06:28 AM
