still no tec
Old Jun 8, 2006 | 07:09 PM
ls weez's Avatar
Default still no tec
just got obd2 ta obd1 conversion harness, and a gsr computer plugged it in and still no vtec only thing i got is a oil leak by the oil filter could this be the problem cause iam not building enough oil pressure. also does any one have a wire digram for a 94and up gsr
Old Jun 8, 2006 | 07:13 PM
lVlemphizStylez's Avatar
Default Re: still no tec (ls weez)
http://technet.ff-squad.com/wiring.obd1.htm
Old Jun 8, 2006 | 07:54 PM
ls weez's Avatar
i tried wiring the vtec solenid from the engine into the the #4 wire that goes to the vtec soliend on the ecu and the car ran like **** what could be the problem iam i missing something
Old Jun 8, 2006 | 07:57 PM
wait can you better explain what you did....you can run a hardwire from the vtec solenoid (green and yellow wire) to the ecu (using pins)
Old Jun 9, 2006 | 06:57 PM
ls weez's Avatar
Default Re: still no tec (lVlemphizStylez)
what i did was i ran a wire from the vtec solenid (on the engine) to the the ecu's vtec soliend (in the car) i just tired the two wire's in on the ecu. know iam thinking do i need ta wire it up to the ecu ta make it work?
Old Jun 9, 2006 | 09:53 PM
the vtec solenoid should have only one wire though...you have to use pins if there is an empty slot...or if you have a jumper harness you can spice into the wires on the harness since it already has pins in all the appropriate slots
Old Jun 9, 2006 | 10:03 PM
Danza's Avatar
a lack of oil pressure would cause vtec to not engage, but I think it'd take more than a leak.
Old Jun 9, 2006 | 10:06 PM
Default Re: still no tec (Danza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danza &raquo;</TD></TR><TR><TD CLASS="quote">a lack of oil pressure would cause vtec to not engage, but I think it'd take more than a leak.</TD></TR></TABLE>
chipped ecu takes care of that sensor....so depending on his ecu that wouldnt be an issue
Old Jun 9, 2006 | 10:08 PM
Danza's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">
chipped ecu takes care of that sensor....so depending on his ecu that wouldnt be an issue</TD></TR></TABLE>
gotcha
Old Jun 10, 2006 | 05:12 PM
FunIntegras's Avatar
Did you use your stock wireharnes from the swap, or did you use a GSR wire harness. You should use your stock wireharness from the car.
Old Jun 10, 2006 | 05:18 PM
ls weez's Avatar
Default Re: still no tec (FunIntegras)
iam using my stock wire harness
Old Jun 10, 2006 | 08:49 PM
akstunt600's Avatar
yeah it would have to be litterally squirting out oil not alot but it would have to be a constant drain for vtec to not work.
is the dowel pin in center cam cap in place along with the lil blue o-ring???
other than that u a have to be looking at the pin-outs in correctly, remember some are copied backwards, and obd0 pins are 135
246
and obd1 and 2 are 123456
14 15 16 etc....
Old Jun 10, 2006 | 09:53 PM
ls weez's Avatar
Default Re: (akstunt600)
yea its a constant drain come out when ever i hit..plus iam seeing tons of smoke in my rearveiw cause its droping from the oil fiter on to the block.. just ta make sure though can anyone explain ta me the steps in wireing the soilend and the switch.. and how does the soniend get its power?
h22killer
Engine Management and Tuning
Oct 1, 2011 04:57 PM
THEDirtyDseriesWOOT
Jun 13, 2007 06:38 AM
ilovemyb16a
May 18, 2006 12:58 PM
mr. carpenter
May 5, 2004 09:47 PM
Baggy Spandex
Jul 15, 2003 12:50 PM
