clutch problem
well as the title states
im having clutch problems
a frend and i looked at it and realized it wasnt the clutch at all.
he said its most likely the throw out bearing since the clutch isnt disengaging from the transmission
what can i do to fix this?
try bleeding it first. if that doestn work, you might have to pull the tranny out. im guessing its a fck'ed up disc.
i forgot add this. check to see if your clucth master cylinder is leaking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazyvietboi »</TD></TR><TR><TD CLASS="quote">try bleeding it first. if that doestn work, you might have to pull the tranny out. im guessing its a fck'ed up disc.
i forgot add this. check to see if your clucth master cylinder is leaking.</TD></TR></TABLE>
its not hydraulic (the clutch), so i wouldnt need to check or bleed anything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddie p »</TD></TR><TR><TD CLASS="quote">does it go into gear when the car is off?
check your cable to make sure that it didnt stretch and that its working properly</TD></TR></TABLE>
it struggles to go into gear while the car is off, but it does.
checked it, tightened it, works fine, problem remains
im takin the trans out tomorrow morining to actually SEE whats wrong.
also, another frend of mine said it could b the pressure plate.
he didnt back it up or anything. could that have anything to do with it?
Drizzo
13
Aug 5, 2004 08:44 AM
civic_speed99
13
Jul 16, 2004 08:19 AM
