clutch problem
Old Jun 7, 2006 | 01:39 PM
B-JUSTINE's Avatar
Default clutch problem
well as the title states
im having clutch problems
a frend and i looked at it and realized it wasnt the clutch at all.
he said its most likely the throw out bearing since the clutch isnt disengaging from the transmission
what can i do to fix this?
Old Jun 7, 2006 | 01:51 PM
lazyvietboi's Avatar
try bleeding it first. if that doestn work, you might have to pull the tranny out. im guessing its a fck'ed up disc.
i forgot add this. check to see if your clucth master cylinder is leaking.
Old Jun 7, 2006 | 01:55 PM
__oversea's Avatar
Default Re: clutch problem (B-JUSTINE)
whats up with the cluch problem lately..lol
what is the problem?? lol
Old Jun 7, 2006 | 02:24 PM
B-JUSTINE's Avatar
Default Re: (lazyvietboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazyvietboi &raquo;</TD></TR><TR><TD CLASS="quote">try bleeding it first. if that doestn work, you might have to pull the tranny out. im guessing its a fck'ed up disc.
i forgot add this. check to see if your clucth master cylinder is leaking.</TD></TR></TABLE>
its not hydraulic (the clutch), so i wouldnt need to check or bleed anything
Old Jun 7, 2006 | 03:09 PM
sohc it to me's Avatar
Default Re: (B-JUSTINE)
does it go into gear when the car is off?
check your cable to make sure that it didnt stretch and that its working properly
Old Jun 7, 2006 | 03:31 PM
B-JUSTINE's Avatar
Default Re: (eddie p)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddie p &raquo;</TD></TR><TR><TD CLASS="quote">does it go into gear when the car is off?
check your cable to make sure that it didnt stretch and that its working properly</TD></TR></TABLE>
it struggles to go into gear while the car is off, but it does.
checked it, tightened it, works fine, problem remains
Old Jun 7, 2006 | 03:34 PM
B-JUSTINE's Avatar
when i try to put it in gear w/ the car on it grinds, in every gear
btw, its a 92 ls w/ 197xxx miles, stock
Old Jun 7, 2006 | 03:38 PM
CleanLikeJdm's Avatar
Hype-R Stalker
If you think it's your throwout bearing .. you need to take off the trans.
Old Jun 8, 2006 | 12:22 AM
B-JUSTINE's Avatar
im takin the trans out tomorrow morining to actually SEE whats wrong.
also, another frend of mine said it could b the pressure plate.
he didnt back it up or anything. could that have anything to do with it?
Old Jun 8, 2006 | 08:51 AM
Nors's Avatar
It is part of the clutch assembly, so yeah it could have something to do with it, I'd bank on throw-out bearing.
Apocolipse269
Nov 5, 2004 08:06 PM
picott
Sep 27, 2004 12:24 PM
Drizzo
13
Aug 5, 2004 08:44 AM
civic_speed99
13
Jul 16, 2004 08:19 AM
User 5426
Aug 1, 2003 06:36 AM
