B16 Idleing at 2000 RPMs Please Help.
its a vacuum leak somewhere did you replace the throttle body? it could be a leak there. or a vacuum hose not connected. spray some carb cleaner or starting fuid around gaskets and fittings and see if the engine sound changes then you will know where it is leaking from
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nexgen91 »</TD></TR><TR><TD CLASS="quote">i didnt replace the TB I checked the throttle cable no luck there, and the idle adjustment screw is all the way in. thanks</TD></TR></TABLE>
when did it start idling high then? if it isnt those problems, it's got to be something else....... has it always did this, or just happen yesterday on its own, out of the blue?
there ya go.... vacuum leak somewhere, iacv maybe? fast idle valve? throttle cable? a ton of options. just go through them one by one.
killahatch
Apr 27, 2009 10:14 AM
FlatLineEG8
Mar 4, 2004 04:47 PM
