idleing problem
I have a similar issue. The idle tends to fluctuate between 1000-1500 rpm. A mechanic told me it wasn't something too serious, but the throttle body needed replaced to resolve it... Anyone know for sure?
Welcome to Honda-Tech.
Try the search feature located here:
https://honda-tech.com/zerosearch
It should be more than helpful
This is a fairly common problem.
1st thing you should do is make sure the car is not throwing any codes.
2nd clean out your IACV which is located on the back of your IM..
3rd check for vacum leaks, ussualy on pr3 intake manifolds there is a nipple that has to be plugged. Sometimes when people do swaps they forget to plug this nipple which causes an irratic idle.
check those 3 things, its probably something very small...
The IAVC is on the bach of the IM. When you take it off it has a little screen on it. The screen can get very dirty so just spray some brake cleaner on it. It'll clear it rite up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPORT GiRL1320 »</TD></TR><TR><TD CLASS="quote">Instantaneous Automatic Volume Control</TD></TR></TABLE>
ehhhhh how bout Idle Air Control Valve? Here is a how-to in order to clean it out.
https://honda-tech.com/zerothread?id=1575913
Import Girl, i hope you are joking...
Modified by DeadEnd9009 at 2:57 PM 6/14/2006
veearr6
Mar 12, 2010 01:12 PM
eL
21
May 2, 2004 03:42 PM
