Tech Savvy peeps help with idle/stall problem!!!
Old Mar 28, 2003 | 06:02 PM
HaUTSaauce's Avatar
New User
Default Tech Savvy peeps help with idle/stall problem!!!
had a proble with my car idling t 2k-3k so i adjusted the FITV cleaned my TB, IACV and TPS sensor.
no i dont have a problem with the car idling at 2k-3k any more in fact when i start the car up it idles at 100 rpms and slowly rises to just under 1k and stays there till i apply gas then the rpm drop hella low and the motor cuts out.
i have done numerous searches on this topic and still cant ge this bug worked out
Old Mar 29, 2003 | 04:00 AM
HaUTSaauce's Avatar
New User
Default Re: Tech Savvy peeps help with idle/stall problem!!! (HaUTSaauce)
bump
Old Mar 29, 2003 | 11:23 AM
HaUTSaauce's Avatar
New User
anyone?
Old Mar 29, 2003 | 06:14 PM
HaUTSaauce's Avatar
New User
is there anyone who can help?
Old Mar 29, 2003 | 06:54 PM
asmallsol's Avatar
what engine you running and ecu. Also are you running Hondata?
Old Mar 29, 2003 | 06:59 PM
mmuller's Avatar
Mad Scientist
idle screw?
what did you do with the tps?
Old Mar 29, 2003 | 07:41 PM
R@mon's Avatar
Default Re: Tech Savvy peeps help with idle/stall problem!!! (mmuller)
i have the same problem on a customers b16 hatch.
we replaced the intake manifold with a itr one and i think it have a manifold leak so im gunna check it out tommorow.
Old Mar 30, 2003 | 05:39 AM
asmallsol's Avatar
Default Re: Tech Savvy peeps help with idle/stall problem!!! (93h22a4)
http://www.hondaswap.com/articles/viewer.php?id=55
One of my freinds at hondaswap had this problem. He tried everthing and finally got a normal idle. Click on that link. You might have to be a member to veiw it.
Old Mar 30, 2003 | 04:12 PM
HaUTSaauce's Avatar
New User
Default Re: Tech Savvy peeps help with idle/stall problem!!! (asmallsol)
b16 head, gsr block, type r head, p72 ecu, ys1 tranny
i adjusted te tps sensor trying to fix this problem it did bring th idle from 2k dwn to 800ish but the car still stalls out after applying gas
i will double check the idl screw
[Modified by HaUTSaauce, 6:13 PM 3/30/2003]
veearr6
Mar 12, 2010 01:12 PM
gmuas
Mar 6, 2008 12:58 PM
andysila
Apr 4, 2006 06:46 AM
stRtypR25
Jan 12, 2003 03:09 PM
