anyone in here paint there own cars at home?
Old Jun 3, 2006 | 03:12 PM
ChampWhiteTegra's Avatar
Default anyone in here paint there own cars at home?
im painting my RHD eg as we speak , just wanna see what everyone else is using as far as venting and exhaust fans and such.
Old Jun 3, 2006 | 03:28 PM
E-Rok's Avatar
EPIC TUNING
Default Re: anyone in here paint there own cars at home? (ChampWhiteTegra)
appearance forum?
Old Jun 3, 2006 | 06:10 PM
blueoval557's Avatar
Default Re: anyone in here paint there own cars at home? (. r e w s n a e h T)
I didnt use anything when I did mine in my garage. Wet the floor down to catch all the airborne contaminents, cracked the front and rear roll up garage doors a little and went to down. Once your in there and have your mask on, you should be fine. After painting, walk out, leave the garage doors cracked a bit and come back when the flash time is done with.
Kyle
Old Jun 3, 2006 | 06:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . r e w s n a e h T &raquo;</TD></TR><TR><TD CLASS="quote">appearance forum?</TD></TR></TABLE>
id say this is in the right place since your doin it your self
and thanks kyle what paint did u use and what gun, i have a sata NR2000 and using single stage nason , thats a dupont paint, and pics of the car ?
Old Jun 3, 2006 | 06:47 PM
HighRevn's Avatar
You should have used the nason basecoat /cleacoat at the least. I only use single stage on rims. You should have looked into Diamont, its made by BASF and has some of the best tints around. Plus if you ever have to touch up it will always match(most body shops use this line when matching paint). What tip are you using??
Old Jun 3, 2006 | 09:10 PM
19civic93's Avatar
Default Re: anyone in here paint there own cars at home? (HighRevn)
I paint in my garage all the time. I drop plastic from the ceiling to create a booth inside the garage. For intake and exhaust fans I use 20" box fans with furnace filters on them. Before painting I turn off my furnace and water heater.
Old Jun 4, 2006 | 08:32 AM
Default Re: anyone in here paint there own cars at home? (19civic93)
I did the same thing with the plastic. Just lined all the walls basically to a create a little booth. I used the cheapy gun from my local paint shop, which was stil $150 but looks identical to the $40 ones at harbor freight, I think they jipped me. I used the PPG OMNI Base Coat/Clear Coat setup. Only picture I have on this computer is the one below. I have pictures of it in the stages of paint as well though. Every piece was taken off, except the motor, and painted off the car, then reassembled. Deck lid, doors, interipor was gutted, front fendedrs, bumpers, hood, etc. Turned out really well though. I sold it, but I loved the car.
Kyle
Old Jun 4, 2006 | 10:25 AM
Default Re: anyone in here paint there own cars at home? (blueoval557)
im using a 1.4 tip. i did the jams and the bumpers today and so far so good, of course il be wets sanding and buffing. any one else doing this?
Old Jun 4, 2006 | 06:57 PM
BoogieDownBrown's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChampWhiteTegra &raquo;</TD></TR><TR><TD CLASS="quote">im using a 1.4 tip. i did the jams and the bumpers today and so far so good, of course il be wets sanding and buffing. any one else doing this?</TD></TR></TABLE>
IF you can, switch to a 1.3 tip when you clear.it leaves a better finish and reduces the chance of runs. the 1.3 tip lays down alot better. Screw your material tip all the way in and then back it out 2 1/2 turns.
Also for ventalation just grab 2 20" floor fans. have 1 push the fumes out and the other pull the fumes out almost giving you a cross draft effect.
Other than that........I hope you're welding something also,because this is the welding and fab forum just jokin'
i hope it works out for ya.
Old Jun 5, 2006 | 01:49 AM
Default Re: anyone in here paint there own cars at home? (BoogieDownBrown)
i welded my RHD firewall
Old Jun 5, 2006 | 08:55 AM
B18EG6's Avatar
this link may help you
https://honda-tech.com/zero...87138
Old Jun 5, 2006 | 11:49 AM
vegaskurt's Avatar
Default Re: anyone in here paint there own cars at home? (B18EG6)
This may also help. https://honda-tech.com/zerothread?id=1531842
Old Jun 6, 2006 | 04:00 PM
Default Re: anyone in here paint there own cars at home? (vegaskurt)
painted the whole car today i must say it came out outstanding, il have pics up shortly
Old Jun 6, 2006 | 10:12 PM
swoyEKr.'s Avatar
I think the prolem enlies more to the result of how to keep dirt out of the drying paint and out of the spray. I'm painting my ek but i'm using my uncles shop, if you're going to do it in the garage or something you better make sure you blow back the garage from top to bottom before you spray. Keeping some sort of exhuast fan at the bottom of the garage door would be a smart decision, and it's almost impossible to keep dirt out of the finish since your going to be bringing unfiltered air in which may contain dirt or even bugs can make thier way in. Blowing back the garage will help to keep any cureent dust in the garage out of the finish. The best way though obbiously would be to use a paint booth, but not everyone has the access. good luck guys
Old Jun 7, 2006 | 09:19 AM
98-DC4's Avatar
here's ome guys home made spray booth from team-integra http://www.team-integra.net/fo...58517
Old Jun 7, 2006 | 09:59 AM
RCautoworks's Avatar
Default Re: anyone in here paint there own cars at home? (98-DC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98-DC4 &raquo;</TD></TR><TR><TD CLASS="quote"> here's ome guys home made spray booth from team-integra http://www.team-integra.net/fo...58517 </TD></TR></TABLE>
, the only thing I dislike is the amount of space. It seems like at time you can be rather close to the car.
Old Jun 7, 2006 | 12:45 PM
fventura03's Avatar
wow, great thread. i was thinking of doing flat black, but now, this thread made me want to do a nice colour.
Old Aug 16, 2006 | 04:58 AM
fventura03's Avatar
mas
Old Aug 16, 2006 | 10:37 AM
boosted94cx's Avatar
* B A N N E D *
we've already done 2, and are in the process of doing one more at my friend Eugene's house. he's doign all the spraying...just basic iwata gun, and we put up plastic for walls and on the floor and make sure it's all 100% clean.
i mean, who can complain...i'm getting a free in/out paint job, a free gallon of eternal blue peral Dupont, and all i had to do was give him a 93 hatch i bought for $250 and buy a gallon of omni black primer..haha.
but, as for venting....fan in the window, closed all doors...and we all stayed the hell out while he sprayed. the paints not so bad, but the clear is horrible. he always wears a suit and respirator while in there.
Old Aug 16, 2006 | 05:19 PM
newuser333's Avatar
Yeah, I've painted several cars. The garage is exactly perfect for painting. I have one exhaust fan blowing up into the "attic" of the garage. I hang plastic floor to ceiling around the walls to keep paint off of everything else.
It's amazing how even with an HVLP gun paint (especially clear) still gets on everything.
All in all, it's work and not exactly cheap. The last car I did was a 2 tone base/clear job. With all the masking, unmasking, and drying time it took a full 10 hours to paint that car. And over $500 in material.
But, a comparable job would be well over $2000 (I priced them first) so I guess it's still worthwhile.
Old Aug 16, 2006 | 05:58 PM
Niles's Avatar
Default Re: (newuser333)
A really good forum for car paint and body work:
(not that honda tech isn't )
http://autobodystore.com/forum/index.php
nico91civic
Paint and Body
17
Apr 13, 2009 05:47 AM
Mr. EF
Paint and Body
14
Sep 23, 2008 07:28 PM
Thateguhate
Paint and Body
Sep 15, 2008 04:14 PM
racebucket_eg
Paint and Body
45
Nov 9, 2007 04:14 PM
xcom
Feb 29, 2004 03:08 PM
