head bolts stuck!!! How to remove?
Old Jun 3, 2006 | 09:59 AM
wood 1's Avatar
Default head bolts stuck!!! How to remove?
D15 head bolts (2) won't budge, can I heat block to remove or what do I do to get them out? Really does any have a tip for removal?
Old Jun 3, 2006 | 10:09 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: head bolts stuck!!! How to remove? (wood 1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wood 1 &raquo;</TD></TR><TR><TD CLASS="quote">D15 head bolts (2) won't budge, can I heat block to remove or what do I do to get them out? Really does any have a tip for removal?</TD></TR></TABLE>
1/2dr breaker bar will do the trick.
Old Jun 3, 2006 | 10:12 AM
exsinnovation's Avatar
breaker bar
Old Jun 3, 2006 | 10:14 AM
wood 1's Avatar
Default Re: head bolts stuck!!! How to remove? (LSVT3K 91 C1V1C)
Breaker bar did not wokk even with a 4 foot pipe on it!
Old Jun 3, 2006 | 11:06 AM
PAStA MAAAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wood 1 &raquo;</TD></TR><TR><TD CLASS="quote">Breaker bar did not wokk even with a 4 foot pipe on it!</TD></TR></TABLE>
hmmm.... remember "righty tighty lefty loosy"
Old Jun 3, 2006 | 11:24 AM
blah13's Avatar
Default Re: head bolts stuck!!! How to remove? (PAStA MAAAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PAStA MAAAN &raquo;</TD></TR><TR><TD CLASS="quote">
hmmm.... remember "righty tighty lefty loosy" </TD></TR></TABLE>
haha, good advice. But if they really wont come out with a 4ft breaker...your probably screwed. You could try some PB blast and rap of them a little with a hammer to help it sink in and try again. Other than that you'll probably end up shearing the bolt head off or something.
Old Jun 3, 2006 | 01:05 PM
wood 1's Avatar
constructive help only please, I do know how to use a wrench.
Old Jun 3, 2006 | 01:12 PM
SSJSubgeta's Avatar
try cleaning them up from any derbis around the head of the bolt, clean the area well then spray PB blaster, coat the them with a spray every 5 min, and wait the 5 min exactly try it 3 times and clean up any excess oil from the pb blaster use your wrench try removing them now, if it still wont budge use the extention pipe on it. CAUTIN if you do notice that the head of the bolt is being shred stop do not continue as it will get worst take your car to a shop where they can loose them up for you with an impact wrench, well as a last resort that is. GL
Old Jun 3, 2006 | 02:15 PM
wood 1's Avatar
Default Re: (SSJSubgeta)
Thanks for your response, I have already tried an impact wrench, At this point I think there is no way to get this head off. Looks like it is time to throw it in the trash. Any other ideas?????
Old Jun 3, 2006 | 07:44 PM
Crx Jimmy's Avatar
try putting back in the head bolts on either side of them and tighten real tight, it might relieve pressure on the one you are taking out
Old Jun 3, 2006 | 11:19 PM
89hatcher's Avatar
i just had this same problem with my motor...i grinded the top of the bolt all the way down with my dremel and grinding stone...make sure you don't grind or touch the valve spring or else your gonna have to replace them...and then your gonna have to use new bolts or use arp head stud thats what i did...and make sure you clean the head really good after you done
Old Jun 4, 2006 | 12:39 AM
Cuda70's Avatar
Default Re: (89hatcher)
Take a brass drift and knock the crap out of the head bolt straight down. Then use the impact wrench again and it should zip right off.
Make sure you run a tap in the bolt hole before reassembly to make sure the threads are perfect again.
Old Jun 4, 2006 | 06:29 AM
puredragcrx's Avatar
Havent seen anyone show the cutting torch some love so ill throw that in there. Use a rose bud tip and apply heat the the bolt head about 35-45 seconds should be long enough. Then have a friend standing by with the breaker bar and extension to throw on there as soon as the torch is removed.
CLEAN HEAD BEST AS POSSIBLE OF OIL TO KEEP DOWN ON FIRE. worst case is you might ghave to replace damged seals around that bolt.
Old Jun 4, 2006 | 09:01 PM
Oh yea! what order did you take the head bolts out? did you do the corect sequence?
InvaderTrax
Oct 6, 2006 06:28 AM
motorhead_ls
Jun 23, 2006 03:28 PM
LSEGHATCH
Aug 14, 2005 09:02 AM
SPEED123
Nov 29, 2003 12:49 PM
Gonzo_SiR
Nov 3, 2003 11:35 AM
