what do i get next?
Old May 31, 2006 | 09:41 PM
speedysohc's Avatar
Default what do i get next?
i have a 97 del sol si W/ i/h/e
i want to get a new ecu and something else, then get it tuned. i dont have the $ for a turbo. what kind of ecu do i get and what should i get along with that?
replies needed... thnx
Old May 31, 2006 | 09:45 PM
sol2hatch's Avatar
Default Re: what do i get next? (speedysohc)
ummm, whats wrong with the ECU you have? you could chip that, but I dont think you would be spending your money wisely. Usually you chip an ECU for more complex upgrades.
Try searching and finding the other countless threads like this one, maybe they have an answer for you.
Old May 31, 2006 | 09:48 PM
Vtakkk's Avatar
nothin, you just need a new ecu, and if you get a chipped one with basemap and your car may be a little off until you get it tuned. Like my idle sat at 2.5 when I first start my car after the ecu, but everything ran hella better with it.
Old May 31, 2006 | 09:55 PM
speedysohc's Avatar
so keep my p28 and get it chipped?
i also meant what other part should i get to mod my engine, in other words make some power?
sol2hatch's Avatar
Default Re: what do i get next? (Vtakkk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtakkk &raquo;</TD></TR><TR><TD CLASS="quote">nothin, you just need a new ecu, and if you get a chipped one with basemap and your car may be a little off until you get it tuned. Like my idle sat at 2.5 when I first start my car after the ecu, but everything ran hella better with it.</TD></TR></TABLE>
I am not sure what you just said, but it sparked my interest. Did you chip your ECU with just bolt on upgrades, and get a big difference?
Old May 31, 2006 | 09:58 PM
sol2hatch's Avatar
Default Re: (speedysohc)
if you want to make power, and not spend money, then go get totally wasted, passout, and start dreaming.
You should save your money for a turbo or a swap, those are just about the only reasonable ways to make some repectable power.
Old May 31, 2006 | 10:00 PM
speedysohc's Avatar
i realize i can do that but as far as staying d series how can i produce more power
not looking for a v8 killer just a sohc that will suprise people
Old May 31, 2006 | 10:04 PM
4dohs4mohoes's Avatar
Default Re: what do i get next? (sol2hatch)
If I were you, I would just stick with what you have, save your money, then do it all at once.
And you can make a y8 a V8 killer.
Old May 31, 2006 | 10:05 PM
thehatchninja's Avatar
buy a spare d16z6 head. Buy a crower cam and valvesprings. Take the head to a machine shop and have it milled .040. Then have the shop put it all together. Put that on your engine with a chip from j-k-tuning.com or phearable.net....then get it tuned and cut much ***.
Old May 31, 2006 | 10:06 PM
Default Re: (thehatchninja)
just go to d-series.org. http://www.d-series.org/forums...21761
Old May 31, 2006 | 10:07 PM
sol2hatch's Avatar
honestly, there is not really any other way. You can get minimal gains from things like underdrive pulleys, chips, and other little stuff, but if you want more than those, then you need to save your money. You can bolt stuff on all you want, but that stuff will just be kind of a waste of money. If you want to have a faster car, and dont want to spend alot of money, look into weight reduction. Not a huge difference, but it helps and it is free. I had a stock si del sol, and I swapped that engine into my CX hatch, added some bolt ons, and the weight difference helped alot. My car will surprise people. Look into some suspension mods, there is more to driving then going fast you know
Old May 31, 2006 | 10:15 PM
FalkenSiR's Avatar
Default Re: (sol2hatch)
Turbo D16Z6 FTW
Old May 31, 2006 | 10:18 PM
sol2hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 &raquo;</TD></TR><TR><TD CLASS="quote">Turbo D16Z6 FTW </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja &raquo;</TD></TR><TR><TD CLASS="quote">buy a spare d16z6 head. Buy a crower cam and valvesprings. Take the head to a machine shop and have it milled .040. Then have the shop put it all together. Put that on your engine with a chip from j-k-tuning.com or phearable.net....then get it tuned and cut much ***.</TD></TR></TABLE>
He said he doesnt have the money for a turbo, and i dont think he would have the money for all that other stuff either.
Old Jun 1, 2006 | 09:28 PM
speedysohc's Avatar
thnx for all the replies that actually suggested things
most people will just flame but an answer to my question is what i was looking for and i got it thanks all
Old Jun 1, 2006 | 10:14 PM
tallyturbo's Avatar
chip the ecu instead of getting a new one because one day you might go turbo. then you dont have to worry about it.
Unseen Racer
Aug 29, 2008 08:37 AM
hondaEg_808
Mar 25, 2008 11:10 PM
pxsx
Sep 26, 2007 07:29 PM
Doubledeala
Oct 15, 2004 05:00 AM
5STAR3
Mar 20, 2004 04:40 PM
