how to open a T3 internal w/g?
Old May 29, 2006 | 06:57 AM
.kyle's Avatar
Default how to open a T3 internal w/g?
i searched found nothing on how to. . .found out that i wont be boosting which is good temporarily so i can put in a new clutch. . but how can i open my wastgate. . i have a T3 with an internal w/g . .
Old May 29, 2006 | 08:09 AM
.kyle's Avatar
Default Re: how to open a T3 internal w/g? (IWantATurbo)
bump anyone? is it easy?
Old May 29, 2006 | 11:03 AM
StylishDOHC's Avatar
Disconnect the actuator from the wastegate flapper.
Old May 30, 2006 | 02:26 PM
.kyle's Avatar
Default Re: how to open a T3 internal w/g? (StylishDOHC)
bump
Old May 31, 2006 | 04:50 PM
.kyle's Avatar
bump more detailed? everything looks so solid on it. . where does it separate?
Old May 31, 2006 | 06:58 PM
HiProfile's Avatar
Open as in take it off, or open as in prevent boost? Theres a good chance even an open flapper on an internal gate (particularly with a small turbo) will not prevent at least some boost. Best thing is to 'open it' as well as put on a cheap rubber coupler somewhere in lines and put a large slice through it. That combo will prevent all but 1-2 psi of boost, which the stock ecu can deal with to an extent, and still be safe w/o any tuning.
As how to do this - take the wastegate actuator (the canister on a metal stock, think lollypop) and disconnect the end of the stick from the lever sticking out of the wastegate housing.
Old Jun 4, 2006 | 07:47 AM
.kyle's Avatar
Default Re: how to open a T3 internal w/g? (HiProfile)
so if a leak in intercooler piping makes no boost. . if i dont want any boost temporarily. . could i just disconnect the piping from the compressor. . .? instead of ruining a coupler? couldnt i just take a coupler off?
Old Jun 4, 2006 | 08:45 AM
.kyle's Avatar
bump
Old Jun 4, 2006 | 10:59 AM
Si Shane's Avatar
Dont disconnect your compressor from the intake manifold. You run a high risk of damaging your turbo.
The actuator arm should be threaded you have to disconnect it from the flapper, which what the arm rotates when it slides back and forth.
Old Jun 4, 2006 | 09:59 PM
HiProfile's Avatar
Default Re: how to open a T3 internal w/g? (Si Shane)
As stated, disconnecting the compressor is bad, you could overspin the turbo. The reason I mention making it leak is so there is some load on the compressor.
Adding both a leak and open actuator combined with lighter driving will prevent boost.
V-SPEC 1
Feb 19, 2013 07:43 PM
hondaguyexsi
Aug 10, 2005 12:00 PM
1boostedcivic
Sep 23, 2004 05:06 PM
ITSTOCK
Apr 14, 2004 07:37 PM
DA666
Apr 3, 2002 08:12 AM
