this boost controller okay?
Old May 31, 2006 | 08:21 PM
mike93boost's Avatar
Default this boost controller okay?
i have a turbosmart MBC. was wondering if it would be okay on my 400+whp ~25-27psi d16 setup? if not what would you use?
Old May 31, 2006 | 09:09 PM
Kelly.'s Avatar
I've quit using this account
i personally use a profecb spec 2.
it seems to be holding ~ 25 psi on my d fine
prior to that, i used a turbo xs MBC,
it worked great until ~18 psi.
after that i wasnt sure if the problem was the BC or the turbo spinning to high (19t greddy turbo)
if i was you, i get the profec, alot of people use them on high boost apps without problem.
good luck
Old May 31, 2006 | 09:16 PM
yea but ive heard so many bad things about electronic boost controllers. all my dsm buddies run 22+psi all the time on mbc's.
Old Jun 1, 2006 | 03:06 AM
bigdaddyvtec's Avatar
* B A N N E D *
Default Re: (mike93boost)
if you are set on a MBC, i suggest the Hallman pro RX..its pretty badass.... I run one, and its great...Looks good too, also there is an option for a cable setup to make it adjustable from the cockpit. They are around 100 bux, use a ceramic ball for quick reaction and come wuith two springs... one for lower boost, and one for higher settings.
Mine is stable as hell, does NOT creep... AT ALL. Highly reccomend it.
Old Jun 4, 2006 | 09:03 PM
probably get a hallman. but any other suggestions? going to be running approx 25psi??
Old Jun 4, 2006 | 09:12 PM
oxhernandez's Avatar
Get a AVCR
Old Jun 4, 2006 | 09:45 PM
qfast817's Avatar
Default Re: (oxhernandez)
im running turbo smart duel stage and it works fine
Old Jun 4, 2006 | 10:29 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxhernandez &raquo;</TD></TR><TR><TD CLASS="quote">Get a AVCR </TD></TR></TABLE>
I agree if you are looking for a EBC, the AVCR is the ****. Too rich formy blood when I built the car, but coming soon, then Ill sell the Hallnman PRO RX, but the Hallman works flawlessly.
Sketch_hs
Jun 30, 2005 12:55 PM
Antilag
May 12, 2005 05:24 PM
yusoslo
Feb 25, 2004 07:28 PM
Accord94DX
Jul 22, 2003 02:06 PM
