valve guides?
u have to heat up the head, but just take it to a machine shop. if ur replacing them b/c a bent valve the seats r going to be marred anyway so u need to have the seats cut to fit the new valves or else ur just not goin to get a proper seal. i would reccomend replacing the valve seals too while ur head is off
heat up the head with some map gass and rip em out then, becarefull when replacing them its a delicate process they must be flush when re-installed u may also have to reheat the head to get them in too.
no special tool needed however there is one just use pliers
80 dolla crx hf
Sep 8, 2014 01:28 PM
