Need Help Obd2-Obd1 distributor wiring (searched)
Old May 27, 2006 | 07:57 AM
ExplicitSpeed360's Avatar
Banned.
Default Need Help Obd2-Obd1 distributor wiring (searched)
I have seen a few different wire matches ups that make me liery below is what I used and was boomslang.us is it right or wrong for the obd2-obd1 dist. color wire match ups...TIA
97 ex obd2a going obd1 h22a prelude
Old May 27, 2006 | 12:12 PM
Banned.
Default Re: Need Help Obd2-Obd1 distributor wiring (ExplicitSpeed360)
anyone? more then one way to skin a cat?
Modified by ExplicitSpeed360 at 1:25 PM 5/27/2006
Old May 27, 2006 | 05:51 PM
Banned.
Old May 27, 2006 | 07:00 PM
HondaPartsHero's Avatar
Technical Hero
it's either that one or this one, can someone confirm?
Old May 27, 2006 | 08:35 PM
Banned.
Default Re: Need Help Obd2-Obd1 distributor wiring (HondaPartsHero)
Yeah thats the one that got me trippin...anyone confirm which is right or are they both right?
Old May 29, 2006 | 06:12 PM
Technical Hero
http://stores.ebay.com/HONDAPA....html
Modified by HondaPartsHero at 10:31 PM 5/29/2006
Modified by HondaPartsHero at 12:18 AM 5/30/2006
Old May 29, 2006 | 09:26 PM
Banned.
so boomslang.us who makes harness fuked up?
Old May 29, 2006 | 09:33 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero &raquo;</TD></TR><TR><TD CLASS="quote">it's either that one or this one, can someone confirm?
I have used this one without a problem.
On the boomslang one, blk/yel is not ign output. It is 12v switched for the coil. I have not checked the boomslang one.
Old May 29, 2006 | 09:55 PM
Banned.
Default Re: Need Help Obd2-Obd1 distributor wiring (Turbogixxer)
if it matters guys the dizzy is an internal coil anyone 2nd this?
Old May 29, 2006 | 09:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExplicitSpeed360 &raquo;</TD></TR><TR><TD CLASS="quote">if it matters guys the dizzy is an internal coil anyone 2nd this?</TD></TR></TABLE>
No, It is actually easier. The dizzy plug if the civic will plug and play into the OBD1 prelude, follow the guide in the H22a thread that hondzivc made to convert it to external.
You have to run the blue tach signal wire to the driver side connector for the stock tach to work.
I should really read the OP question
Old May 29, 2006 | 10:03 PM
Banned.
the above chart has instead of green to green for TDC my wire is orange/blue to green and there is no orange/blue wire listed above there is also another wire different that is orange solid too
Old May 29, 2006 | 10:05 PM
Banned.
which makes me think there is some differences in colors of wiring like there should be 2 charts
Old May 30, 2006 | 08:28 AM
Banned.
Okay I made this and light blue according to the plugs goes with the big black/yellow wire on the civic plug. The Darker Blue is below in the pack of wires. So should I just match up plug positions instead of colors?????
Modified by ExplicitSpeed360 at 10:38 AM 5/30/2006
Old May 30, 2006 | 12:00 PM
Banned.
There are 2 blue wires one is on the top next to the black/yellow wire it is a lighter blue then the blue down below in the cluster on the civic plug....???
Old May 30, 2006 | 12:54 PM
Technical Hero
updated, let me know if it works
Old May 30, 2006 | 05:16 PM
Banned.
looks right!!! here is mine!
Old Jan 10, 2008 | 09:02 AM
Rywire's Avatar
this is how i do mine..
obd0 -------------------- obd2
thick solo white(alone on bottom)----------------- yel/grn
blu/grn -------------------- blue
blue/yel ----------------------- white
orng/blu ----------------------- grn
wht/blu --------------------- red
orng ------------------------- yel
white ------------------------- black
-Ryan
PS, then the 2 pin plug, just match up the blue and yel/blk.... if you have a 8 pin d series 2b connector.... here is what you do.
color match the blk/yel and take the blue wire from the 2 pin obd0 side, and tap that to the yel/grn on the obd2 side. This shares the tach with the igniter, getting signal...
Spoon Si
Nov 30, 2008 05:28 PM
talonturbotsi94
Aug 18, 2007 05:23 PM
PNPFLIPPED
Jun 19, 2006 07:55 PM
ExplicitSpeed360
May 27, 2006 12:31 PM
