Car is running rough? Hot outside?
well this is my first turbo car....and it has been great so far....the weather is changing and today was hot as hell and i had to drive my car a lot today....car was idling pretty rough and shut off twice on me.....it seems like the car is idling lower that it normally would.......that car is pulling a bit less vacumn as the boost gague reads....normally it reads vac to 10".....now its vac to 5" and i have a greddy profec b spec II and it usually reads -99 at idle sitting still now its at -78/-85 during the day when its hot....i think that i need the car retuned to fix the idle and also the a/f because the car is running up to 12.5 at WOT on 10lbs.....
any input would be greatly appreciated....just seems like the car is running a bit sluggish, and i know all of my n/a car ran a big rougher when the summer came around, just want to know if its worse when its extremely hot.
thanks in advance......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict »</TD></TR><TR><TD CLASS="quote">what ems?</TD></TR></TABLE>
u my friend have a boost leak or a small vaccume line u should alwasy be at 10-15hg and ur greddy should be reading 99 at idle no matter what
but when it gets u should also change to a heat range of 9-10 and regap ur spark plugs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16adx »</TD></TR><TR><TD CLASS="quote">isnt normal vacuum 18-21?</TD></TR></TABLE>
thats what i thought, thats what mine does at least...
Razor
Apr 29, 2002 12:21 AM
