Car is running rough? Hot outside?
Old May 26, 2006 | 08:56 PM
allmotorsi04's Avatar
Default Car is running rough? Hot outside?
well this is my first turbo car....and it has been great so far....the weather is changing and today was hot as hell and i had to drive my car a lot today....car was idling pretty rough and shut off twice on me.....it seems like the car is idling lower that it normally would.......that car is pulling a bit less vacumn as the boost gague reads....normally it reads vac to 10".....now its vac to 5" and i have a greddy profec b spec II and it usually reads -99 at idle sitting still now its at -78/-85 during the day when its hot....i think that i need the car retuned to fix the idle and also the a/f because the car is running up to 12.5 at WOT on 10lbs.....
any input would be greatly appreciated....just seems like the car is running a bit sluggish, and i know all of my n/a car ran a big rougher when the summer came around, just want to know if its worse when its extremely hot.
thanks in advance......
Old May 27, 2006 | 01:39 PM
a1320addict's Avatar
Default Re: Car is running rough? Hot outside? (allmotorsi04)
what ems?
Old May 27, 2006 | 03:46 PM
AbitAvenger's Avatar
Default Re: Car is running rough? Hot outside? (a1320addict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">what ems?</TD></TR></TABLE>
Old May 27, 2006 | 05:37 PM
akstunt600's Avatar
u my friend have a boost leak or a small vaccume line u should alwasy be at 10-15hg and ur greddy should be reading 99 at idle no matter what
but when it gets u should also change to a heat range of 9-10 and regap ur spark plugs
Old May 28, 2006 | 11:31 AM
Default Re: (akstunt600)
running crome
Old May 28, 2006 | 11:35 AM
Soccerking3000's Avatar
Default Re: (allmotorsi04)
do you have the ECT and IAT corrections correct?
Old May 28, 2006 | 01:01 PM
b16adx's Avatar
Default Re: (Soccerking3000)
isnt normal vacuum 18-21?
Old May 28, 2006 | 01:42 PM
Default Re: (b16adx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16adx &raquo;</TD></TR><TR><TD CLASS="quote">isnt normal vacuum 18-21?</TD></TR></TABLE>
thats what i thought, thats what mine does at least...
redboost10
Jan 20, 2007 02:22 PM
buzlink
Mar 27, 2006 08:57 AM
AP-Signworks1
Jul 23, 2004 06:44 PM
Razor
Apr 29, 2002 12:21 AM
