Is this all I need to run turbo on my b18c1
Old May 26, 2006 | 07:43 PM
teggywepower
Guest
Posts: n/a
Default Is this all I need to run turbo on my b18c1
Garrett t3/to4e turbo
Hemsfab ramshorn exhaust manifold
Tial sport 38mm wastegate with 6pound psi spring
Tial sport 50mm blow off valve
Custom built downpipe
Custom built 3inch turbo exhaust
chipped p-28 ecu
Intercooler
i/c piping
Dsm 450cc injectors
Walbro 255 lph fuel pump
Ob2-ob1 ecu harness
Do I need anything more this is all on a b18c1 gsr motor
Old May 26, 2006 | 08:13 PM
Spec R's Avatar
Default Re: Is this all I need to run turbo on my b18c1 (teggywepower)
oil lines/fittings
Old May 26, 2006 | 08:16 PM
Spec R's Avatar
couplers/clamps/ vacuum hose / vacuum hose couplers / gauges
Old May 26, 2006 | 08:26 PM
jonvo's Avatar
resistor box for injectors and obd1 injector clips
Old May 26, 2006 | 08:32 PM
stealthmode62's Avatar
Default Re: Is this all I need to run turbo on my b18c1 (DC2xSiR)
A boost gauge.
Old May 26, 2006 | 09:30 PM
teggywepower
Guest
Posts: n/a
Default Re: Is this all I need to run turbo on my b18c1 (stealthmode62)
Where could I find a reseister box for the injectors. First of all why is one needed.
Old May 27, 2006 | 03:38 AM
top end tuner's Avatar
Default Re: (Spec R)
whats the vacuum hose for
Old May 27, 2006 | 04:11 AM
crxnj's Avatar
Default Re: (top end tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggywepower &raquo;</TD></TR><TR><TD CLASS="quote">Where could I find a reseister box for the injectors. First of all why is one needed. </TD></TR></TABLE>
any 88-91 civic/crx si or hf and 90-91 integra..others may work but i cant speak 100% on them so im not gonna say..
Old May 27, 2006 | 08:28 AM
morgan@synapse motorsport's Avatar
i thougth dsm 450's were saturated?
Old May 27, 2006 | 08:33 AM
crxnj's Avatar
Default Re: (hybrdthry911)
they're peak and hold .
Old May 27, 2006 | 06:22 PM
Spec R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by top end tuner &raquo;</TD></TR><TR><TD CLASS="quote">whats the vacuum hose for</TD></TR></TABLE>
The wastegate, blowoff, boost gauge, and boost controller all need vacuum hose to operate correctly.
95dc2teg
Nov 11, 2006 04:01 PM
Altered
Jan 1, 2004 07:18 PM
Spudddy
Apr 16, 2003 06:39 PM
M.A.R.C.
Aug 26, 2002 12:33 PM
M.A.R.C.
Jun 25, 2002 07:31 PM
