car is acting funny?
Old May 21, 2006 | 10:46 AM
sirhatch90's Avatar
Default car is acting funny?
will some one help me please. i have a hatch with a jdm 16 and nothing done to it but a vafc 1. it is throwing a codes 3 that means map censor. right? ok i got that; now will a vafc make it throw that code?
and today i was camming home from work and i could not get it to go past 3 grand because it starting missfiring so bad that when it did get that hi it would back fire..
i know this is my first post but will some one help me...
Old May 21, 2006 | 04:01 PM
thevtecnician's Avatar
Default Re: car is acting funny? (sirhatch90)
The vafc1 won't make your car throw a code but it could make it bog out like that if it isn't setup right. Also check your vacuum lines on your map sensor and make sure its plugged in and the lines are in the right place. My dohc zc did that 2 me and my map sensor plug had fallen out
Old May 21, 2006 | 09:14 PM
sirhatch90's Avatar
Default Re: car is acting funny? (thevtecnician)
ok i replaced the map today and still throwing a code 3 i dont know what is going on
Old May 21, 2006 | 10:07 PM
jeremydde's Avatar
VAFC is wired inline with the map sensor to fool the ecu into adding/subtracting fuel. If the "IN" and "OUT" map sensor wires going into the VAFC are backwards, or have poor connections then you would get a code 3. Also if you have the VAFC tuned too far to one extreme, ie way way too rich or lean, it may also trigger a the map code as the ecu is trying to understand what is going on. This case would be a "false" code as everything is functioning/wired correctly.
Old May 23, 2006 | 05:26 PM
sirhatch90's Avatar
Default Re: car is acting funny? (jeremydde)
ok thanks how do you set the vafc to the stock settings?
Old May 24, 2006 | 05:28 PM
jeremydde's Avatar
In the menu there is an option to reset to default, although I can't remember how to do it. Check the manual and it'll tell you how to reset it.
Old May 27, 2006 | 03:10 PM
sirhatch90's Avatar
ok i reset it now and going to see what happens now thank you i think i am still throwing a code 3
Old May 27, 2006 | 03:46 PM
90hatch268's Avatar
reset the ECU
pull the hazard fuse under the hood and wait for a min then put it back in and see what happens
Old Jun 1, 2006 | 06:04 AM
sirhatch90's Avatar
Default Re: car is acting funny? (90hatch268)
i did jeff now what do i need to do?
Old Jun 1, 2006 | 08:40 AM
90hatch268's Avatar
if you set the vafc back to stock, then reset the ecu. is it still throwing a code? did you reset the ecu? are you sure? pull the hazardx fuse under the hood out for a min, then put it back in and see if your still throwin codes or dont have a clue what im talking about, just give me a call i'll meet you up and do it bro.
Old Jun 1, 2006 | 04:47 PM
sirhatch90's Avatar
yeh i pulled the fuse and put it to stock still throwing code
whitestreak
Mar 3, 2007 05:56 AM
South Bay Surfer
Dec 24, 2004 02:15 PM
Mugen Mike
Jun 19, 2003 09:19 AM
crxtreme27
Aug 9, 2002 09:22 PM
