300 hp turbo d series???
Old May 20, 2006 | 04:09 PM
xDicktonesx's Avatar
Default 300 hp turbo d series???
just curious, what kind of power are you people gettign out of boosted d series motors? with aftermarket pistons and rods. what size compressors are you using? just totally curious becuase im seeing single cam vtec motors for like 450 bucks. people gettgin beat with the **** they threw away.
Old May 20, 2006 | 06:34 PM
d16vtecx's Avatar
Default Re: 300 hp turbo d series??? (xDEFTONESx)
i too would like to see some setups
Old May 20, 2006 | 06:58 PM
Default Re: 300 hp turbo d series??? (d16vtecx)
seriously, i was just sitting around scratching my head thinking, for the price of a STOCK gsr swap and a decent turbo set up you could have a nicely built d series motor with a nice custm setup and money left to spare. i just wanna see what numbers a d-series will make with rods, pistons, stock sleeves and say 18-20psi on 91 octane gas, if the sleeves can even handle that.
Old May 20, 2006 | 07:21 PM
txsynergy's Avatar
Golden Eagle Sleeves (75mm)
CP piston
Eagle Rods
Every gasket, bearing, etc replaced
stock head
T3/T04e 50 trim .63A/R
Revhard mani
300hp/250tq @ 16lbs
Old May 20, 2006 | 07:27 PM
Gold DA9's Avatar
Default Re: 300 hp turbo d series??? (txsynergy)
http://www.turbod16.com
They have alot of info there.
Old May 20, 2006 | 07:48 PM
igo4bmx's Avatar
check my sig
Old May 20, 2006 | 08:00 PM
00bluslut's Avatar
Default Re: (igo4bmx)
freinds D series made 312.7hp @ 8800, 18psi, 91 octane, stock sleeves, Ebay turbo kit, 9.0 CR, had room for about 10-20 hp but owner did not want to push it. It beat my GSR on 10 PSI. Both Cars Stoopid Tuned.
Modified by 00bluslut at 9:56 PM 5/20/2006
Old May 20, 2006 | 10:29 PM
nerdsports's Avatar
im not built, but on a completely stock motor i made 273whp and ran a 12.1 @ 12.5psi.
350whp can be easily achieved w/ the right turbo setup and tune (on a built bottom end).
Old May 20, 2006 | 10:40 PM
912's Avatar
912
Default Re: (00bluslut)
ebay kit it ss auto crome
Old May 20, 2006 | 10:56 PM
nerdsports's Avatar
Default Re: (912)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 912 &raquo;</TD></TR><TR><TD CLASS="quote">ebay kit it ss auto crome</TD></TR></TABLE>
uhhh. hell no
Old May 20, 2006 | 11:36 PM
4potnick's Avatar
Default Re: (nerdsports)
300 whp guys. Any probs with headlift. I have a d15b15g shootnig for 235-250whp on a stock motor and a couple exttras? d15b on hmotors are $435.
Old May 20, 2006 | 11:38 PM
thomas@LPS's Avatar
one guy on here has 424whp on stock sleeves w built bottom end. im in the process of boosting my stock motor right now. im gonna build another motor then see how much power i can make on a total stock block. i will keep u updated on #'s when i get them. i dont think u could really go wrong w a d16.
Old May 21, 2006 | 10:15 AM
nerdsports's Avatar
Default Re: (4potnick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4potnick &raquo;</TD></TR><TR><TD CLASS="quote">300 whp guys. Any probs with headlift. I have a d15b15g shootnig for 235-250whp on a stock motor and a couple exttras? d15b on hmotors are $435. </TD></TR></TABLE>
headstuds are a must on a boosted d16. they lift the head rather easily.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_ex_95 &raquo;</TD></TR><TR><TD CLASS="quote">one guy on here has 424whp on stock sleeves w built bottom end. im in the process of boosting my stock motor right now. im gonna build another motor then see how much power i can make on a total stock block. i will keep u updated on #'s when i get them. i dont think u could really go wrong w a d16. </TD></TR></TABLE>
unfortunately achieving ~400whp isn't the easiest task on a d16. the head does not flow that well, so you'll need a good head job to get it flow enough to make around 400whp.
Old May 21, 2006 | 10:32 AM
conceptEG's Avatar
go to epictuning.com look at their project car.. they ran 11.60s on a stock d16z6 with arp head bolts and a neptune..its cake to piece together a decent kit for cheap..though i admitt its all in the tune..you should check out homemadeturbo.com as well..you can get some pieces out of a junk yard using dsm parts..
later and good luck..
Old May 21, 2006 | 12:31 PM
phresh_5's Avatar
Check out my friends car... 363whp 331.7TQ Stock Sleeves
This was with a .48 exhaust housing. That's why the TQ falls off. He's now running a .63 exhaust housing but we havn't gone back to the dyno yet.
http://www.vancouvercivics.com...50423
EZ$$EF
18
Nov 6, 2015 11:09 AM
ham
Apr 11, 2007 08:26 AM
VtecKiDD
Feb 1, 2006 10:59 AM
Arturbo
Dec 19, 2003 11:42 AM
