fuel line upgrade
Old May 20, 2006 | 01:33 PM
rudebwoy's Avatar
Default fuel line upgrade
how hard is it to change or upgrade the fuel lines in a 95 civic coupe, not that I need to upgrade but a part of my fuel line is damaged and I would like to change it, or upgrade it to stainless steel.
so my question is how hard would it be to take it out and replacing it?
Old May 20, 2006 | 01:49 PM
coneheadsracing's Avatar
Default Re: fuel line upgrade (rudebwoy)
the rubber one from the fuel pressure riser? Just put in regular fuel line. If you are going to upgrade everything, its not hard, more pricey then anything. Theres a post around here recently today that showed a sump pump, i think its called, with stainless lines, ask him.
Old May 20, 2006 | 02:15 PM
rudebwoy's Avatar
Default Re: fuel line upgrade (coneheadsracing)
its damage right below the filter, maybe I can just cut it there and put a piece of rubber or stainless line in.
Old May 20, 2006 | 06:47 PM
stealthmode62's Avatar
Leroy, you can get a 37 degree flaring kit at some auto stores and possibly at summit, ect. Run AN fittings off of that.
Old May 20, 2006 | 07:06 PM
Default Re: fuel line upgrade (stealthmode62)
yeah, you can change that to stainless.... someone prolly even sells a kit for it. I thought you were talking about the return line, which is just fuel hose.
Old May 21, 2006 | 12:41 AM
rudebwoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote">Leroy, you can get a 37 degree flaring kit at some auto stores and possibly at summit, ect. Run AN fittings off of that. </TD></TR></TABLE>
do you have a pic of what it looks like so I can go hunting for one, O have limited resources in this country, I miss the US.
Old May 21, 2006 | 10:42 AM
http://www.amazon.com/gp/produ...28013
How to:
http://www.carcraft.com/howto/50919/index1.html
Check out the May issue of Honda Tuning and they modified the stock hardline going into the fuel filter converting it to stainless and then running all the BDL fuel stuff.
Old May 21, 2006 | 01:01 PM
rudebwoy's Avatar
thanks steve! I have this tool in my work place for years and did not know what it was, it looks so simple, now I need to see if I can barrow it since I don't work there anymore.
h22acivichybrid
Jun 14, 2004 03:20 PM
95hybridcivic
Jan 27, 2003 09:23 AM
justinCO
Jun 7, 2002 08:55 PM
