Enigne is running like crap!
Guest
Posts: n/a
I just finnished my ls rebuild and the engine is running rough. i lined up the camshaft arrows and lines and lined the crank up to TDC. The engine started right up, but when i went to time it the timing line was way out of adjustment. I have the rotor in the dizzy pointing on cylinder number one and the inductive clamp for the timing light on spark plug wire number one. My question is why is the timing so retarded.
Have you tried adjusting the dizzy? If the cams are not perfectly set to the crank then the dizzy will read incorrectly. I know you already double checked, but a tripple check may reveal something else. Be sure the slack on the t-belt is on the back side of the motor (closest to fire wall). Only a little slak should be evident.
Guest
Posts: n/a
i got the timing dead on now and the enigine is is still running rough. It sounds great under the hood, but when you go back to the exhaust it putts almost sounds like a WRX. i did a compresion test and its 195 or better across. Someone help me before i blow this thing up. motor is still in its break in period. 345 miles, ive following the break in process. anyone know whats going on?
civic89si666
12
Dec 21, 2006 02:48 PM
