Window problem
Old May 18, 2006 | 05:09 AM
Jorsher's Avatar
Default Window problem
Alright so I have a 97 Civic EX and the window came out of the track again last night, the track near the tweeter pod. It's always slow and seems to stick as it goes up but when I removed the door panel to put it back on the track I didn't see anything it could be binding on. Any idea why it would keep popping out of the track? It's a major PITA to fix and the door panel is a pain to get back on because it's falling apart. Thanks.
Old May 18, 2006 | 09:01 AM
Jorsher's Avatar
ttt
Old May 18, 2006 | 09:14 AM
S CARTER's Avatar
Default Re: Window problem (Jorsher)
Windows Bind or Come Out of the Run Channels
(Supersedes 98-082, dated October 27, 1998)
SYMPTOM
One or more windows are binding or have come out of
the run channels.
PROBABLE CAUSE
Damaged or incorrectly installed glass run channels.
CORRECTIVE ACTION
Replace any damaged glass run channel(s), or
correctly reinstall the glass run channel(s), and adjust
the channels.
Old May 18, 2006 | 09:19 AM
Unit44justin's Avatar
Ive been having this problem too but by the tweeter the window is hanging up on the rubber window seal when i try to put the window up it makes it about half way i havente replace it yet but im hoping thats all it is.
Old May 18, 2006 | 09:21 AM
Jorsher's Avatar
Thanks. That's what it seems like. Any idea how to adjust them? I remember one long screw near the run channel that maybe you can adjust it with.
Old May 18, 2006 | 09:23 AM
Jorsher's Avatar
Default Re: (Unit44justin)
Yeah mine too, the window will come out of the track near the tweeter pod side, then it will actually get on the wrong side of the weatherstripping and get stuck when I try to roll it up. I think the problem is actually the doorhandle side track, don't think it's aligned right and so the tweeter side of the window is popping out.
Old May 18, 2006 | 10:27 AM
i would still try replacing the weather stripping since you say it is kind of sluggish new stuff actuall has a like an oily type substance on it that eventually wears off after a some years and after it wears off the dry rubber creates friction which creates the sluggish part which can eventually wear out the motor. i would suggest just replacing it still
Old May 18, 2006 | 12:42 PM
Flar's Avatar
yea replace the channel (front or rear, or both if you want to be sure). My passenger window is fine after I replaced them. My drivers side just started doing this same crap. You can lube the channels for a while, but then it will make the problem worse once the lube dries out.
Also (probably unlikely) check and make sure that your window is actually sitting straight to begin with. If you pull off your door panel, you'll see these two feet that hold the window at the bottom. If one of those is even a little loose your window won't go up straight, which could be why its popping off the channel too.
NightCat
11
Apr 18, 2009 03:05 PM
i-want-a-crx
Oct 13, 2007 08:41 AM
Silverdot
Jun 24, 2006 04:42 PM
C2daIzZle
16
Sep 9, 2005 05:06 AM
Berwyn74
Nov 17, 2003 10:21 AM
