throttle has itchy trigger finger
Old May 13, 2006 | 06:50 PM
hb_guy's Avatar
Default throttle has itchy trigger finger
just finished a 5 speed swap and my throttle at low rpms jumps while i am driving in gear.
during idle you can rev the car and it revs happy, but when you start to drive it starts to bog and go bog again and go - but only at lower rpms - less than 3k - after that it is fine.
any ideas. not sure where to start.
car 91 civic ex 4 door with auto to manual swap
rebuilt d16a6 block
43k mile d16y7 head
i/h/e
89 si trans
centerforce df clutch
ps9 ecu still
btw - tps was working fine on other motor before whole swap
i did not check for codes yet, tomorrow morning i will though.
Old May 13, 2006 | 06:53 PM
e jay one's Avatar
Default Re: throttle has itchy trigger finger (hb_guy)
did you mess with the timing at all? did you adjust the clutch cable? thats weird
Old May 14, 2006 | 07:07 AM
hb_guy's Avatar
Default Re: throttle has itchy trigger finger (e jay one)
no i am going to mess with the timing today(on the dizzy side). the other timing is fine. clutch has been adjusted also. i will be posting my findings in an hour or so.
Old May 14, 2006 | 08:19 AM
hb_guy's Avatar
no codes!!
adjusted timing on dizzy.. runs better now, but when i let off the throttle in second gear it surges a bit. any ideas? clutch adjustment??
Old May 14, 2006 | 05:36 PM
hb_guy's Avatar
anyone?
Old May 15, 2006 | 06:03 PM
mikede's Avatar
ive been having the same problem on my 91 si. if you figure it out let me know.
Old May 15, 2006 | 09:48 PM
IndySporty's Avatar
try doing your TPS voltage adjustment. .5 closed and 4.5 WOT
Old May 16, 2006 | 05:09 AM
hb_guy's Avatar
Default Re: (IndySporty)
i'm not throwing codes, i doubt its tps
famdakam
11
Dec 27, 2018 08:15 AM
freakasis
Feb 24, 2007 01:27 PM
d16y7hatch
Oct 30, 2006 08:57 PM
aquabob89
Apr 25, 2006 10:02 AM
Civiclx
Jan 13, 2004 03:04 PM
