can coolant cause 3-3.5k idle?
Old May 12, 2006 | 12:53 PM
huge230's Avatar
Default can coolant cause 3-3.5k idle?
I am having a hard time with my H22 turbo. I have a really high idle and cant find a vacuum leak anywhere. I even blocked to FICV and IACV and its the same. I am also having trouble getting the air out of the cooling system. Can that cause the idle? And how do i get the air out of the system?
Old May 12, 2006 | 12:55 PM
burnitup's Avatar
i doubt it check your pcv valve. check the blow by too.
Old May 12, 2006 | 01:39 PM
raene's Avatar
Default Re: can coolant cause 3-3.5k idle? (huge230)
Start spraying all the seals and gaskets with a water bottle.
Old May 12, 2006 | 02:00 PM
huge230's Avatar
Default Re: can coolant cause 3-3.5k idle? (raene)
ok im going to try that
torinharrington
Jun 14, 2013 07:29 PM
thekid2390
Apr 11, 2013 11:25 AM
BlueLude84
Sep 18, 2008 09:30 AM
AZNracerx1989
Dec 14, 2005 12:01 AM
Ian in Oz
Jun 4, 2003 10:21 AM
