This is the stupidest question I've ever had to ask: Which way does one move when TIG welding?
Old May 10, 2006 | 02:33 PM
Slammed90lude's Avatar
Default This is the stupidest question I've ever had to ask: Which way does one move when TIG welding?
So, I've been trying to master TIG welding. Thought it would be a walk in the park, and thus far it hasn't been too bad.
I was reading up on the subject and realized most sites are talking about pushing the puddle along the seam and adding filler to the leading edge of the puddle.
I've been pulling the puddle along the seam, and adding the filler to the rear of the puddle (with a bit of difficulty).
I'm an idiot aren't I?
Old May 10, 2006 | 03:06 PM
blueoval557's Avatar
Default Re: This is the stupidest question I've ever had to ask: Which way does one move when TIG welding? (
Defenitely add filler to the leading edge of the puddle. By adding it to the trailing edge, two things have already happened by the time you add filler. One, the heat has lowered because your torch is already focused on a different piece of the base metal. Secondly, the shielding gas has somewhat disapated, making contamination a bigger factor in the end weld.
So...add tot he leading edge, and keep practicing!
GOOD LUCK!
Kyle
Old May 10, 2006 | 03:24 PM
More importantly though, I should be pushing the puddle along the weld?
Old May 10, 2006 | 03:28 PM
david@didrace.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed90lude &raquo;</TD></TR><TR><TD CLASS="quote">
I'm an idiot aren't I?</TD></TR></TABLE>
Yeah, kinda.
Old May 10, 2006 | 03:33 PM
On the up side, I managed to weld some pretty slick looking beads in the wrong direction
Old May 10, 2006 | 07:01 PM
dfoxengr's Avatar
Default Re: (Slammed90lude)
basically if youre right handed. torch in right, filler in left, move left.
im left handed so its opposite.
-derek
Old May 11, 2006 | 06:45 AM
wade's Avatar
Default Re: (dfoxengr)
i am ambidextrous! yay for me!
Old May 11, 2006 | 07:13 AM
RMF
Guest
Posts: n/a
Default Re: (wade)
Whenever I'm welding something I try to start away and bring it to me.When you weld towards yourself you can see what your GOING to weld not what you have ALREADY welded.
Old May 11, 2006 | 07:23 AM
wade's Avatar
Default Re: (RMF)
i might try it that way for kicks and giggles today, something i have never tried yet.
Old May 11, 2006 | 08:04 AM
weiRtech's Avatar
OG Fabricator
i thought the ideal position would be perpendicular to your base metal for the best penetration and equal heat dissipation. angling the torch is so you can see what you're doing. i usually push the puddle, but when i'm doing pipe i try to stay closer to perpendicular to the radius of the pipe... whatever works for you, i know guys who swear by dragging the puddle.
TOAB
Welding / Fabrication
21
Jul 8, 2021 08:26 AM
jdmISmyGOD
Mar 18, 2011 10:43 AM
b16bri
36
Jan 16, 2011 04:51 PM
tepid1
Paint and Body
Apr 9, 2010 02:15 AM
GsR HtCh
Feb 10, 2003 06:09 AM
