Dumb question.... maybe?!?!
Old Apr 8, 2010 | 04:31 PM
tepid1's Avatar
Default Dumb question.... maybe?!?!
So, this is probably a dumb question, but I can't seem to find a clear answer.
I'm shaving my engine bay. I have welded up holes and shaved the studs in the firewall. I'm at the point where I am adding filler. I'm using Rage Extreme for filler. I've also got some spots down to bare metal. Should I be coating the metal with etch primer then applying the filler on top of that or is it OK to apply the filler directly to the bare metal/scuffed surface?
What's the preferred method in my case?
Old Apr 8, 2010 | 04:49 PM
nsxter's Avatar
Default Re: Dumb question.... maybe?!?!
its ok to put filler on bare metal as long as its a scuffed surface
Old Apr 9, 2010 | 02:15 AM
tepid1's Avatar
I've done that. I'v actually tried to chip away at filler on the bare metal. It has a good bite on the metal and is not easy to get off.
I was a bit nervous there for a min.
Thanks
got_no_sol
Jun 10, 2010 06:00 PM
KA-9
Feb 13, 2006 11:04 AM
92eg6
Dec 24, 2004 09:30 PM
DarkTeg94
Nov 22, 2004 08:41 AM
