02 sensor heater wire ?
Old May 9, 2006 | 07:59 AM
hedtrip's Avatar
Default 02 sensor heater wire ?
witch of the two black wires is the heater wire on the 02 sensor ? the one under the green . or under the white ?
Old May 9, 2006 | 08:07 AM
JdmB16Eg6's Avatar
65.115.123.226
Default Re: 02 sensor heater wire ? (hedtrip)
bump for same answer
Old May 9, 2006 | 09:16 AM
Relic1's Avatar
it truly does not matter. the O2 heater is simply a resistor and polarity does not matter with resistors.
If you really need to know, I can look it up for you.
Old May 9, 2006 | 03:11 PM
hedtrip's Avatar
Default Re: (Relic1)
if u would be so kind
Old May 9, 2006 | 03:25 PM
pdiggitydogg's Avatar
Actually, it does matter.
If you wire it wrong (switch them up), you'll throw a cel.
As far as which is which...i used to do trial and error
Old May 9, 2006 | 03:41 PM
Relic1's Avatar
car harness side of the O2 connectors, looking into the connector on the open side. (ie plugs not wires)
AB
CD
A=grn/wht - grn - O2 gnd
B=white - white - O2 signal
C=orn/blk - black - heater neg control
D=yel/blk - black - heater pos
(wire colors are for an EG)
Old May 9, 2006 | 03:43 PM
sicones's Avatar
Default Re: (pdiggitydogg)
actually the 2 black wires on the 02 sensor are both heater wires and the polarity does NOT matter
this is straight from the denso instructions
black - heater
black - heater
white - signal
green - ground
/\ beat me to it
Old May 9, 2006 | 04:04 PM
Strange... Then what would cause the cel prior to switching them around?
Old May 9, 2006 | 04:47 PM
Relic1's Avatar
which CEL? 41 or 1?
Old May 9, 2006 | 04:59 PM
honestly, its been so long i dont even remember which it was
Old May 10, 2006 | 07:16 AM
JdmB16Eg6's Avatar
65.115.123.226
i throw out a low voltage code, dunno if its the o2 sensor or the heater wires
Old May 10, 2006 | 02:50 PM
Relic1's Avatar
Default Re: (JdmB16Eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">honestly, its been so long i dont even remember which it was</TD></TR></TABLE>
1 would make sense. 41 wouldn't. 1 is the O2 sensor portion which matters which wire is which, 41 is the heater which doesn't.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmB16Eg6 &raquo;</TD></TR><TR><TD CLASS="quote">i throw out a low voltage code, dunno if its the o2 sensor or the heater wires</TD></TR></TABLE>
Isn't low voltage an O2 signal code?
Old May 11, 2006 | 10:14 AM
JdmB16Eg6's Avatar
65.115.123.226
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">
Isn't low voltage an O2 signal code?</TD></TR></TABLE>
i dont know what it means
Old May 11, 2006 | 10:33 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">Isn't low voltage an O2 signal code?</TD></TR></TABLE>
It usually is.
Old May 11, 2006 | 11:27 AM
Relic1's Avatar
the only O2 CEL I can find that includes "low voltage" is about the O2 signal not the heater. The O2 signal wires are polarity sensitive.
I'm back to my original statement... reversing the heater wires will not result in a CEL.
Old May 11, 2006 | 06:33 PM
roadrunner1's Avatar
i recently swapped a b16 sirII into my 92 hatch...have not wired in the 4 wire o2 yet but could i wire the black wires together and run the green and white where ever they are supposed to go?
Old May 11, 2006 | 06:35 PM
Default Re: (roadrunner1)
change that...where do the 4 wires run?
Old May 12, 2006 | 07:51 AM
Relic1's Avatar
the heater wires... one runs to the ECU the other runs to ignition power.
the O2 wires... white to the ECU green to ground.
Old May 16, 2006 | 07:47 PM
i just wired my o2 last nite and it is workin fine now...i wired one of the black wires to one the yellow/black wires into the empty plug on the strut tower...the other black wire to the orange/black wire on plug A on the strut tower pass. side...ran the white wire into the stock white one wire on the engine harness...and green to thermostat ground...and everything works great
got_no_sol
13
Mar 25, 2017 12:29 PM
accord2civic2prelude
Oct 11, 2010 07:29 PM
:mR. PotAtO heaD:
Oct 8, 2007 08:55 PM
V3locity
Jul 26, 2004 06:54 AM
HXMan
Apr 26, 2002 08:13 AM
