O2 sensor wiring help
Old Jul 24, 2004 | 03:51 PM
V3locity's Avatar
Default O2 sensor wiring help
On the clip from the car, there is a white, a green, and a black wire w/ a white strip, and a black wire w/ a yellow stripe. On the sensor there is a white, a green, and 2 solid black wires. Does it matter which one is hooked up to which? If so how do I tell?
Thanks!
Modified by drumnbassej1 at 8:17 PM 7/24/2004
Old Jul 24, 2004 | 05:10 PM
grntrex's Avatar
Default Re: O2 sensor wiring help (drumnbassej1)
on the o2 sensor-
green = ground
black = heater wire
black#2 = heater wire
white = signal
on the car-
yellow/black = ground
dont know the rest. sorry
Old Jul 26, 2004 | 06:54 AM
EE_Chris's Avatar
Default Re: O2 sensor wiring help (grntrex)
*Info from 96-00 Civic Helms ETM*
Engine connector:
Pin1 Wht = O2 signal
Pin2 Grn/Blk = O2 signal GND
Pin3 Blk/Yel = +12v (typically from the Alt SP fuse)
Pin4 Blk/Wht = O2 heater control
O2 connector:
Pin1 Wht
Pin2 Lt Grn
Pin3 Blk
Pin4 Blk
So yes, it does matter which wires you connect to each other.
91efbluehatch
13
Nov 7, 2012 06:21 AM
Azelas
Jun 7, 2008 03:19 PM
Ryanman
Jan 6, 2008 10:03 AM
HXMan
Apr 26, 2002 08:13 AM
