should i turbo charge my d16 motor
Old May 8, 2006 | 10:40 AM
akoreanyoungsta's Avatar
Default should i turbo charge my d16 motor
i got a 97 civic sedan and is thinking about turbo charging it or swapping a motor
which one will be better? turbo charging it or swapping the motor?
Old May 8, 2006 | 10:42 AM
ralphie14's Avatar
Default Re: should i turbo charge my d16 motor (akoreanyoungsta)
Both are great, but you will have more potential for the future in the swap. They cost about the same unless you Backyard/ junkyard the turbo set up. You can boost for less than a grand these days
Old May 8, 2006 | 10:47 AM
Default Re: should i turbo charge my d16 motor (ralphie14)
if i turbo charge it how much faster will it be? how much hp will i gain?
ralphie14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akoreanyoungsta &raquo;</TD></TR><TR><TD CLASS="quote">if i turbo charge it how much faster will it be? how much hp will i gain?</TD></TR></TABLE>
To hard to specualate there are way to many facotrs out there.
Old May 8, 2006 | 10:51 AM
icic... aiite thanks for your advice
Old May 8, 2006 | 10:52 AM
96hb's Avatar
Depends on what you want, but I say boost it. You can safely get 200-225 hp out of a stock block d16 with a good tune.
Old May 8, 2006 | 11:07 AM
-Gary-'s Avatar
Default Re: should i turbo charge my d16 motor (96hb)
Boost the explitive out of it.
Old May 8, 2006 | 11:11 AM
Jorsher's Avatar
Yeah, I say f the swap. I am putting together a setup myself right now. Spent $300 and got a .42/.48 t3 turbo, downpipe, log manifold w/ wastegate support...just spent $130 for 450cc injectors, obd2-obd1 conversion harness, and dsm bov. All i need is the pipes, lines, ic, and I'm chipping my own ecu...
Aiming for 190hp with 8psi
Old May 8, 2006 | 11:13 AM
EkLanta's Avatar
swap it. N/A
Old May 8, 2006 | 11:56 AM
DJ_SaNdOz's Avatar
Default Re: should i turbo charge my d16 motor (EkLanta)
Do you want to be slow? (swap) or slightly less slow? (boost)
Old Jun 9, 2006 | 06:43 PM
nightmarecivic's Avatar
Default Re: should i turbo charge my d16 motor (DJ_SaNdOz)
dued honda tunning mag even said that a d16 can beat a DOHC turbo almost stock D16's rule
Old Jun 9, 2006 | 06:45 PM
turboekcivic's Avatar
Default Re: should i turbo charge my d16 motor (nightmarecivic)
BOOOST
Old Jun 10, 2006 | 07:39 AM
dangerranger21's Avatar
Default Re: should i turbo charge my d16 motor (turboekcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightmarecivic &raquo;</TD></TR><TR><TD CLASS="quote">dued honda tunning mag even said that a d16 can beat a DOHC turbo almost stock D16's rule</TD></TR></TABLE> Whaaaa??... I would still prefer my DOHC Vtec Turbo over a D series
Old Jun 10, 2006 | 07:56 AM
Archidictus's Avatar
Unceasing Measure
Don't ask us questions like this without telling us the mileage, modification level, budget, trim level of the car and whether or not you have a hot sister. You can make anywhere from 140whp to 210whp depending on the engine, the boost level, the tune and where your sister puts her mouth.
Old Jun 10, 2006 | 09:20 AM
DaveSi677's Avatar
Default Re: should i turbo charge my d16 motor (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
Don't ask us questions like this without telling us the mileage, modification level, budget, trim level of the car and whether or not you have a hot sister. You can make anywhere from 140whp to 210whp depending on the engine, the boost level, the tune and where your sister puts her mouth.</TD></TR></TABLE>
you are bad but funny!!!!!!!!1
Old Jun 10, 2006 | 09:39 AM
EJ6_ROY's Avatar
How am I to interpret this flagrant befouling of the English language? Are you saying that a d16(Y8 I'm assuming) can beat a turbocharged DOHC motor? Or are you saying that it can ALMOST beat a turbo'd DOHC, and that stock D16's rule? BTW, in what issue did you read this? I'm subscribed to HT and I never read anything like that.
But enough of that.
A guy I know turbocharged his D15B7 and from what I hear it's fast as hell.
Old Jun 10, 2006 | 09:46 AM
srg's Avatar
srg
Yes, That's truth! I beat DOHC all day with my D16z6 not boosted yet
Old Jun 10, 2006 | 09:56 AM
Default Re: should i turbo charge my d16 motor (srg)
So let me get this right? STOCK FOR STOCK; My 99 civic Si would most likely lose to say a civic EX? hehe
Old Jun 10, 2006 | 10:07 AM
EJ6_ROY's Avatar
Maybe the other guy's a shitty driver? Or are you that good?
Old Jun 10, 2006 | 10:09 AM
Default Re: should i turbo charge my d16 motor (rniederlando)
hmmm interesting stuff, didnt know the D series could be up with the DOHC
Modified by dangerranger21 at 12:04 PM 6/10/2006
Old Jun 10, 2006 | 11:09 AM
Default Re: should i turbo charge my d16 motor (dangerranger21)
Actually I would like to see videos of D series turbo'd Does anyone have any or links to them?
Old Jun 10, 2006 | 11:18 AM
sk8shorty012's Avatar
try http://www.turbod16.com and go to the video section.
maal15
18
Dec 4, 2008 11:31 AM
projectef
Jul 3, 2007 08:35 PM
JLman86
18
Apr 20, 2004 07:46 PM
Briman2021
Oct 28, 2003 08:34 AM
S@nt0s
31
Jul 3, 2003 07:17 PM
