should i turbo charge my d16 motor
i got a 97 civic sedan and is thinking about turbo charging it or swapping a motor
which one will be better? turbo charging it or swapping the motor?
Re: should i turbo charge my d16 motor (akoreanyoungsta)
Both are great, but you will have more potential for the future in the swap. They cost about the same unless you Backyard/ junkyard the turbo set up. You can boost for less than a grand these days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akoreanyoungsta »</TD></TR><TR><TD CLASS="quote">if i turbo charge it how much faster will it be? how much hp will i gain?</TD></TR></TABLE>
To hard to specualate there are way to many facotrs out there.
Depends on what you want, but I say boost it. You can safely get 200-225 hp out of a stock block d16 with a good tune.
Yeah, I say f the swap. I am putting together a setup myself right now. Spent $300 and got a .42/.48 t3 turbo, downpipe, log manifold w/ wastegate support...just spent $130 for 450cc injectors, obd2-obd1 conversion harness, and dsm bov. All i need is the pipes, lines, ic, and I'm chipping my own ecu...
Aiming for 190hp with 8psi
Re: should i turbo charge my d16 motor (turboekcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightmarecivic »</TD></TR><TR><TD CLASS="quote">dued honda tunning mag even said that a d16 can beat a DOHC turbo almost stock D16's rule</TD></TR></TABLE> Whaaaa??... I would still prefer my DOHC Vtec Turbo over a D series
Unceasing Measure
Don't ask us questions like this without telling us the mileage, modification level, budget, trim level of the car and whether or not you have a hot sister. You can make anywhere from 140whp to 210whp depending on the engine, the boost level, the tune and where your sister puts her mouth.
1 Post
Re: should i turbo charge my d16 motor (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
Don't ask us questions like this without telling us the mileage, modification level, budget, trim level of the car and whether or not you have a hot sister. You can make anywhere from 140whp to 210whp depending on the engine, the boost level, the tune and where your sister puts her mouth.</TD></TR></TABLE>
you are bad but funny!!!!!!!!1
Re: should i turbo charge my d16 motor (nightmarecivic)
How am I to interpret this flagrant befouling of the English language? Are you saying that a d16(Y8 I'm assuming) can beat a turbocharged DOHC motor? Or are you saying that it can ALMOST beat a turbo'd DOHC, and that stock D16's rule? BTW, in what issue did you read this? I'm subscribed to HT and I never read anything like that.
But enough of that.
A guy I know turbocharged his D15B7 and from what I hear it's fast as hell.
But enough of that.
Re: should i turbo charge my d16 motor (rniederlando)
hmmm interesting stuff, didnt know the D series could be up with the DOHC
Modified by dangerranger21 at 12:04 PM 6/10/2006
beat, charge, charging, cost, d16, ek, engine, honda, motor, nightmarecivic, put, stock, turbo, turbocharge, turbocharging
