Anyone rebuild their own axle? Inboard joint Q
Old Apr 10, 2002 | 11:48 AM
-TJ's Avatar
-TJ
Default Anyone rebuild their own axle? Inboard joint Q
Let's see if I can post yet another unanswerable axle question.....
In the Helm axle section, an arrow points to the inboard joint and it says:
"Do not try to disassemble"
Anyone have any knowlege on how the outboard joint is removed from the axle? It's not like Honda to make something that can't be taken apart.
-TJ
Old Apr 10, 2002 | 12:01 PM
-TJ's Avatar
-TJ
Default Re: Anyone rebuild their own axle? Inboard joint Q (-TJ)
Impatient as I am, I decided to call Marty at Raxles to see if he would be kind enough to answer this question, even though I was not intent on buying anything...
Marty is the man.
Yes, the outer joint is attached to the axle with a spring clip, just like the way the inner joint is held in the differential. Hit the center race with enough force and the outer will pop off.
TheEvilBain_TDB
Jun 30, 2009 08:02 PM
01ethansh
Dec 17, 2008 12:15 PM
92sleepR
Mar 21, 2003 12:40 PM
