speed sensor circuit
Old May 6, 2006 | 09:19 PM
sir2sol's Avatar
Default speed sensor circuit
alright here's the problem: i've got a 94 del sol with a b16a swap in it and the speedo and trip meter doesn't work. i had a short a while ago and it hasn't worked since. i've changed the vss and even tried a different clauster to see if that could be it. all my fuses are good and i've even went as far as changing the plug on the engine harness. i have a diagram from an helms manuel that shows a "speed sensor circuit"...not sure what that is, maybe it could be fried. i'm pretty much in the dark on this one. wouldn't really care but because it's throwing a cel, vtec won't work any ideas?
Old May 7, 2006 | 12:43 PM
sir2sol's Avatar
Default Re: speed sensor circuit (sir2sol)
bump
Old May 7, 2006 | 04:22 PM
MasterKwan's Avatar
VSS CEL code or something else?
Go to the fuel system section of the Helmes. In the index, you'll see VSS. There's a trouble-shooting procedure for finding out what's wrong with the VSS. Follow it and see where it leads.
Looks like it's either a wiring problem or bad ECU according to the manual.
Old May 7, 2006 | 09:51 PM
sir2sol's Avatar
Default Re: speed sensor circuit (MasterKwan)
cool thanks for the info i'll try that first thing in the morning
DarkGriffin3156
Aug 10, 2014 06:00 PM
supra-n-civic
Jun 23, 2009 07:01 AM
DC2man
Mar 3, 2008 07:01 PM
90civichbsi
Mar 19, 2004 04:33 AM
mattt
Nov 26, 2002 08:03 PM
