Weird Problem: B18C1 in 92 DX Bubble
Old May 6, 2006 | 07:23 AM
drshottest718's Avatar
Default Weird Problem: B18C1 in 92 DX Bubble
Ok so I started up my swap and it threw like 4 or 5 codes which I didnt bother to check because I haven't chipped the P28 yet. So yesterday I used the chipped P28 and it starts up smooth but feels like it wants to just die (no CELs btw). I pressed on the gas and all of a sudden the car shuts off. I happened like 2-3 times. I dont know what it could be. Any help? Oh yea and another issue im having is that I have 2 map sensors plugged in. When I disconnect either one of them I get a CEL but if they're both plugged in no CEL comes on. Also, alot of black smoke comes on when I use the chipped p28. Any thoughts? Can it be the computer?
Old May 6, 2006 | 07:25 AM
superiortradingint's Avatar
take pictures of the inside of the ecu for us...front and back side
Old May 6, 2006 | 07:41 AM
SVOboy's Avatar
What bin do you have on the ecu?
Also, two maps is wrong, do you have both of them wired into the same place on the ecu? Mehbe you have a plug for something else plugged into the map and you're ******* it up. Jump the code it throws when you only use one map and tell us what it is.
Old May 6, 2006 | 09:22 AM
boosted civic 2k6's Avatar
Default Re: Weird Problem: B18C1 in 92 DX Bubble (drshottest718)
black smoke = running rich.
ur air/fuel ratio is messed up. i would definately come to a conclusion that it has to do something involving your MAPs. or try switching an ECU with a buddy. plugs in and out no problem right?
Old May 6, 2006 | 06:09 PM
Default Re: Weird Problem: B18C1 in 92 DX Bubble (jxmac2o6)
yea i think it has something to do with the MAP sensors. One is on the throttle body (OBD2 GSR) and the other one is on the firewall right next to the fuel filter (OBD1). Which one should I disconnect? I'll take pics tomorrow if I can remember to. BTW as of right now Im running a chipped p28. Its my friends
Old May 6, 2006 | 06:27 PM
SVOboy's Avatar
I'd use the tb one and try to figure out which plug goes where and which plug is going to the wrong area. Don't forget to get the codes, that'll help.
Old May 6, 2006 | 07:57 PM
IClark19's Avatar
I'm having the exact same problem with the exact same setup. At first I thought it was a burnt or dead O2 but I guess that's not the case. I guess it would have something to do with the 2 MAPs possibly. Keep us updated because I would like to figure mine out too.
*EDIT* I just pulled the MAP sensor on the firewalll by the fuel filter and got codes 3(MAP sensor), 14(IAC), and 43(Fuel Supply System). When the sensor is plugged there are no codes thrown. Who knows what is going on. I'll be glad when I get the turbo setup finished I can just get it tuned.
Modified by IClark19 at 9:12 PM 5/6/2006
Old May 7, 2006 | 10:24 AM
b20vtechb's Avatar
on a dx you will need to use the plug from the map sensor on the firewall for the map sensor on the t/b and then it should work fine.. just leave the other one unpluged. also make sure you don't have the tps and map sensor conectors switched as there the same
Old May 7, 2006 | 12:42 PM
IClark19's Avatar
Default Re: (b20vtechb)
After hours of confusion, my problems have been solved. Thank you b20vtechb. Pulled the plug on the firewall and put it on the TB and runs perfect. I had to tweak the idle a little but car is running excellent. Hope this solves your problem too drshottest718.
Old May 7, 2006 | 01:35 PM
Default Re: (IClark19)
problem solved. I actually solved it on my own and came back to post the results but looks like someone beat me to it lol. thanks alot for the help though. I have to play with the idle to but as of right now its running great and no more black smoke
Old May 7, 2006 | 09:04 PM
b20vtechb's Avatar
glad to of helped
91b18a1ls
Engine Management and Tuning
Apr 14, 2012 01:59 AM
mtkhalid
13
Jan 29, 2009 07:03 PM
ChinoXdope
19
Jul 19, 2008 02:33 PM
jays93eg6
Sep 25, 2006 10:23 PM
drshottest718
May 22, 2006 04:31 PM
