Can the Check Engine Light be caused by the maintenaince required indicator???
Old May 5, 2006 | 02:29 PM
Si_chRis's Avatar
Default Can the Check Engine Light be caused by the maintenaince required indicator???
i was just wondering if a check engine light can be caused by the maintenaince required indicator. this is on a 2000 civic si.
Old May 5, 2006 | 02:31 PM
spoonracer84eg's Avatar
Default Re: Can the Check Engine Light be caused by the maintenaince required indicator??? (JDMaLLDAy050)
NO I am 1000000000% percent sure. I had a 2000 civic si back in the day.
Old May 5, 2006 | 02:32 PM
Default Re: Can the Check Engine Light be caused by the maintenaince required indicator??? (spoonracer84eg)
There is a way you can stick a piece of metal in the jumper for the ecu and it will flash the cel code through your check engine light. Just search and you will find it.
Old May 5, 2006 | 02:34 PM
ZipTieGUy's Avatar
maintenace required is just a light that goes on every set amount of time/miles to remind you to do oil change. you reset the light through a button on the bottom somewhere. check engine light is the real/serious light
Old May 5, 2006 | 02:35 PM
Default Re: (ZipTieGUy)
This should work for you si...
https://honda-tech.com/zerothread?id=1490107
Old May 5, 2006 | 02:36 PM
Si_chRis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg &raquo;</TD></TR><TR><TD CLASS="quote">There is a way you can stick a piece of metal in the jumper for the ecu and it will flash the cel code through your check engine light. Just search and you will find it. </TD></TR></TABLE>
Yea, i was just wondering cuz the car im gonna buy , the guy says the cel is on from a evap line. if i just find the leak and replace the tube, will it fix the problem and the car also boggs which i think is caused by the evap or some other vaccum line that is causinf the cel
Old May 5, 2006 | 03:11 PM
Si_chRis's Avatar
bump
Old May 5, 2006 | 03:21 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMaLLDAy050 &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
What trouble code does it have stored? An evap problem isn't likely to cause a running problem.
Old May 5, 2006 | 04:14 PM
Default Re: Can the Check Engine Light be caused by the maintenaince required indicator??? (Chiovnidca)
He is right it could be the evap line. However you need to find out what code it is before you buy it unless you trust this guy.
Old May 5, 2006 | 05:14 PM
JDM-EJ1's Avatar
No. CEL is not caused by the maintenance required light.
Old May 8, 2006 | 07:42 AM
Si_chRis's Avatar
I found out that the vaccum line coming from the brake booster to the intake manifold was leaking and i fixed that. i think that was causing the CEL.
BiggieBert
Acura TL, RL & ZDX
Sep 20, 2008 08:59 AM
NOKTURNALCARCLUB
Jan 17, 2008 11:01 PM
Importn2oRacer
May 12, 2007 07:05 PM
pens81
Acura TSX
Mar 30, 2006 03:42 AM
VTECVillain
Jan 6, 2002 11:40 AM
