tach going crazy!
Old May 5, 2006 | 08:05 AM
JDM-EJ698's Avatar
Default tach going crazy!
I've got a 98HB w/b16a2 in it and every time I take it past 6grand the tach needle goes crazy!its SI cluster.what can be causing the needle to go crazy???
Old May 5, 2006 | 08:32 AM
sicky's Avatar
grammer nawzi
Default Re: tach going crazy! (shiftknob85)
Distributor
Old May 5, 2006 | 08:40 AM
CRXified's Avatar
to be more percise, its probably teh ICM (ignitor) in the dizzy, do u get missing when u are in the upper RPMS?
had 1 go in my JDM b16 and i took an ignitor out of a CRX dizzy and it worked fine. change it soon cause eventually it will leave u stranded like it did to me and i had to tow my cvic home with my cousins DA teg lol
Old May 5, 2006 | 08:53 AM
SkankyEJ7's Avatar
Default Re: (CRXified)
yeah its something in the dizzy (either ignitor, ignitor wiring, or misfiring)
Old May 5, 2006 | 02:17 PM
redsikiller's Avatar
Default Re: (98ekhx)
I was told that is due to a spark plug blowing out or malfunctioning. I had that problem on my 89 accord. a set of ngk plugs and wires fixed it.
Old May 5, 2006 | 02:35 PM
ZipTieGUy's Avatar
take off your cap and rotor you will see 4 plugs. take them out one at a time use pliers to crunch it a little and put some dialectric grease. do it to all four replace cap and rotor and voila no more crazy tach. shouldnt take more than 5 minutes unless your rotor screw is stripped
miguey310
Jun 2, 2009 12:29 AM
force-fed
May 9, 2006 05:05 PM
turbotime
Sep 25, 2005 10:25 AM
Mike1486
Nov 17, 2004 10:00 AM
sincityEX
Nov 7, 2004 07:38 PM
