the bouncing tach
Old Nov 5, 2004 | 03:03 PM
sincityEX's Avatar
Default the bouncing tach
okay heres one... 92 accord ex. 109k miles, well maintained as i bought it from the original owner who is my boss of 5 years. i have service records and he never had this problem although he babies his cars. it runs excellent until cruising at freeway speeds and jumping into passing gear where the tach starts to bounce up and down and the engine starts to miss. it seems that the problem is worse in the summer and after the car has been ran for long distances. i'm thinking fuel filter but i cant believe that would affect the tach so much. distributor cap and rotor look good and all dist. connections are clean... any ideas out there? thanks in advance.
Old Nov 5, 2004 | 03:29 PM
PrettyLude's Avatar
ignitor is going bad
Old Nov 6, 2004 | 03:52 PM
KatyHonda's Avatar
Default Re: the bouncing tach (lvrudedude)
Ignitor, ignition coil, bad wires, distributor cap crack, rotor crack, even spark plugs can cause these symptoms. Start w/ plugs, and work up in cost. Honda wires are very good and rarely cause problems.
It's not a fuel problem if you're seeing tach variations, it's ignition problem. Determining exactly what component is bad is tricky. That's why shops have igntion oscilloscopes and test equipment.
good luck
Old Nov 7, 2004 | 01:19 AM
raceboy71's Avatar
I had the same problem on my `90 civic si, and it was the ignitor coil in the distributer. I had it changed, problem gone.
Old Nov 7, 2004 | 08:27 AM
numbinside's Avatar
Default Re: the bouncing tach (raceboy71)
had that problem. was the coil
prettylude... what color is ya car... im in laf all the time
Old Nov 7, 2004 | 05:21 PM
sincityEX's Avatar
Default Re: the bouncing tach (numbinside)
so far i've done the plugs and cap and rotor, i know i'll find it eventually. it's a very elusive problem though. had it at a reputable honda shop and they couldnt find anything on the scope. it doesnt do it with the car in park... only when the engine is under load. they wanted to replace the distributor for 350.00 but i wanted some second opinions. thanks for the suggestions.
Old Nov 7, 2004 | 07:38 PM
PrettyLude's Avatar
if you wanted to change the distributor, distributor king sells them for 225
usafhanda
Mar 14, 2012 10:29 PM
force-fed
May 9, 2006 05:05 PM
why8-eg
May 12, 2005 08:04 PM
4door-r
Apr 23, 2004 04:01 PM
slooogsr
Jul 15, 2003 07:19 PM
