honing d16a6
Old May 2, 2006 | 07:14 PM
9 CRX si 1's Avatar
Default honing d16a6
Just wanted to get some info, I just got my head back from the shop along with all new gaskets, pistons, rings, bearings, etc. Before I put them in, I should ball hone each cylinder. Some people are like DON'T do it yourself, others say yeah just drill in and out about 3 times per cylinder. They seem in perfect condition, just should get some cross hatching. I don't want to skimp out on this and really don't feel like taking out the block. Anyone hone their own cylinders with the block still in their car?
Old May 2, 2006 | 07:35 PM
9 CRX si 1's Avatar
Default Re: honing d16a6 (9 CRX si 1)
I'm starting to think, nobody has
Old May 2, 2006 | 09:57 PM
1C9R9X1's Avatar
you mean taking out the internals with the block still in.i think my neck would cramp out before i finished
Old May 2, 2006 | 10:34 PM
downest's Avatar
Default Re: honing d16a6 (1C9R9X1)
Yes you can do it, it's fine. You just need to "break the glaze" on the walls. The point of this is to make a rough surface the new rings will sort of file down on, so they will seat properly. You can do it in-car, but don't use a ball hone, get a 3 stone, they're cheap from sears or Napa. Make sure you use oil or something and clean it up well.
Old May 3, 2006 | 12:28 AM
sporkcrx's Avatar
Default Re: honing d16a6 (downest)
I've done both (self hone and machine shop) and the machine shop hone is THE way to go. I used the three stone (although the helms says to use a ball hone) and it turned out ok. But when I saw the hone and deck job from the machine shop, I'll never do it by hand again....unless it's some ghetto build. The self hone will probably work fine, but the machine hone will probably be a little better.
Aradin
Engine Machining & Assembly
Jul 20, 2015 12:41 AM
usdm_dc2
Sep 30, 2007 06:39 AM
KaRiZMa
Jun 8, 2005 07:19 PM
wm5holla
Jul 19, 2003 08:59 PM
