how to hone a block?
Old Jun 8, 2005 | 04:10 PM
KaRiZMa's Avatar
Default how to hone a block?
i finally got my pistons/rings and my stepdad will be replacing them for me. my mechanic told me that i should "hone" the block first....
Anyone know how to go about doing that, and what will happen if i dont hone it?
basically, the block is in the car right now, were going to replace the pistons and rings. It is a stock, turboed h22a jdm...
Old Jun 8, 2005 | 04:22 PM
N20civicB18's Avatar
Default Re: how to hone a block? (KaRiZMa)
yeah you want to hone it, get a honer, put it on a drill, spray the cylinders down with wd-40, have someone spray the honer as ur going up and down the cylinders till you get a nice criss cross pattern. just search yahoo for cylinder honing.
if you dont hone it your rings will never break in and she will smoke
Old Jun 8, 2005 | 05:19 PM
.dave's Avatar
i HAS questions ?
Default Re: how to hone a block? (N20civicB18)
No offense, but seeing as you didn't even know what honing is I'd say pull the block out and have a machine shop hone it for you. Its a lot safer than risking ******* it up honing it for the first time in your garage. Spend a little bit of money now instead of a lot more again later.
Old Jun 8, 2005 | 07:19 PM
KaRiZMa's Avatar
thanks for the help..
i had a small idea of what honing is i just needed to explain it better to my stepdad... he should know what to do
Ryhaz
10
Jan 14, 2014 07:57 AM
cherryredcivic
Nov 22, 2011 06:13 AM
SnOOpY-NO
Jan 12, 2005 08:09 AM
Robban26
15
Jan 24, 2004 01:31 AM
jg
Mar 7, 2003 12:19 PM
