96 GSR motor into 97 civic EX 5spd - pretty easy right? Tips?
Old May 2, 2006 | 09:43 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default 96 GSR motor into 97 civic EX 5spd - pretty easy right? Tips?
I am going to be swapping in a 96 GSR motor into my 97 civic EX coupe soon. Here's the motor (currently in buddy's 97 hatch):
As far as wiring, according to Katman there shouldn't be ANY extra wiring to be done, other than extending wires because I have a 5-speed VTEC harness already. What wires need to be extended?
With mounts, I read that my stock driver's side upper mount will work. We have a 96 Integra LS parts car that we can use for any other mounts we need. Do I need a 99-00 Si rear lower mount/bracket, or rear tranny mount/bracket, or both? I don't know the difference.
What about the front lower tranny mount? Use my stock D16 one, or do I need one with the GSR tranny I'll be running? It doesn't have one, but I'm wondering which one I should use.
What are all of the mounts I need? The guides I have seen are VERY general IMO.
Finally, I'm running a chipped P28 with Crome. Can I get the GSR running with a P72 map just fine, or do I have to do some wiring for the butterflies on the stock GSR IM? I know nothing about them, other than I want to disable them right?
Forgive me, I'm new to swaps. I'm a D-series turbo ninja (not for long)!
Anything else I need to know about this swap before I get to work on it next week? Tips? Pointers?
Old May 2, 2006 | 11:39 AM
polymath's Avatar
Default Re: 96 GSR motor into 97 civic EX 5spd - pretty easy right? Tips? (boostincoupe)
Mounts you'll need (reuse the others):
-Si Rear tranny/main bracket (huge T-shaped bracket in the rear)
-CRV/Del Sol vtec lower A/C bracket(if you want to use your civic compressor)
-Si upper driver's side bracket (the piece that bolts to the motor behind the t/b cover...GSR piece will not line up)
-Si/Integra/Del Sol vtec lower front tranny bracket
The ECU route is up to you, you can just use a Skunk/blox/etc. manifold w/o butterflies, or you can just remove 'em and bolt the factory GSR manifold back together without them (some people claim this helps, I have no personal experience with it.)
Hope this helps.
Old May 2, 2006 | 12:17 PM
Default Re: 96 GSR motor into 97 civic EX 5spd - pretty easy right? Tips? (Coyote1800cc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coyote1800cc &raquo;</TD></TR><TR><TD CLASS="quote">Mounts you'll need (reuse the others):
Hope this helps. </TD></TR></TABLE>
Good info! What about the driver's side upper mount? Can a 96 integra LS mount work instead of the 99-00 Si? I only ask because I have it available.
Also, I won't be running A/C, P/S, cruise control or any of that jazz. Straight motor.
Question though, what's the best way to remove power steering from my car when I swap the motor? When it was pulled from my buddy's hatch it didn't have P/S, but will I have to swap out my steering rack to run no P/S? I know there's a way to do it without swapping racks, but I don't know how.
Old May 3, 2006 | 07:35 AM
bump
Old May 5, 2006 | 10:13 AM
polymath's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">Good info! What about the driver's side upper mount? Can a 96 integra LS mount work instead of the 99-00 Si? I only ask because I have it available.
Question though, what's the best way to remove power steering from my car when I swap the motor? When it was pulled from my buddy's hatch it didn't have P/S, but will I have to swap out my steering rack to run no P/S? I know there's a way to do it without swapping racks, but I don't know how.</TD></TR></TABLE>
All integra mounts are identical, so the LS mount = GSR mount...no, the LS bracket will not work, you'll have to get the Si bracket.
If you're not going to use your a/c, then either integra or si/crv/delsol vtec a/c bracket will work (the civic compressor won't line up with the integra bracket).
I've seen people seal the system off with fluid inside (it also acts as a lubricant), but ultimately the 'proper' way to do it is replace it with a non-assisted rack.
Old May 6, 2006 | 05:50 PM
Trey's Avatar
25 Year Member
http://www.phear7imports.net/trey/6gen
Old May 6, 2006 | 08:35 PM
zulued's Avatar
Default Re: 96 GSR motor into 97 civic EX 5spd - pretty easy right? Tips? (Trey)
sorry for hijacking i just did the same swap into my 96 civic. but wanted to retain the power steering.
does anyone know what pump and brackets i can use for this.
Old May 10, 2006 | 05:57 AM
Trey's Avatar
25 Year Member
Default Re: 96 GSR motor into 97 civic EX 5spd - pretty easy right? Tips? (zulued)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zulued &raquo;</TD></TR><TR><TD CLASS="quote">sorry for hijacking i just did the same swap into my 96 civic. but wanted to retain the power steering.
Use the pump and bracket that came with the swap.
lyzer227
Jul 6, 2009 01:44 PM
civicmobileone
Apr 25, 2007 12:38 PM
Crab-Cakes
Dec 16, 2003 12:32 PM
(LiTHiUm)
May 15, 2003 12:44 AM
red96
Jun 13, 2002 10:34 AM
