96 LS Auto to Manual Help!!!
Old May 1, 2006 | 05:26 PM
sounthone05's Avatar
Default 96 LS Auto to Manual Help!!!
I have a 95 gsr that was hit and now i plan to swap the motor out to put in my 96 LS auto. How hard is it and if any pics of simular swap. THX
Old May 1, 2006 | 06:23 PM
DC2 Mang's Avatar
Default Re: 96 LS Auto to Manual Help!!! (sounthone05)
you need the gsr ecu, pedal assembly, clutch resovior, clutch mester cylinder, and clutch lines then run them all like the GSR was run
Old May 1, 2006 | 06:51 PM
jtracing919's Avatar
u will need the upper tranny mount for a conversion cause the mount from the frame is different , hasport sells one. lower front tranny mount is also different, but stk honda from manual will work. clutch pedal assy. with mastercylinder, clutch line, complete shift linkage and hardware. PM me if you got any specific questions, i did this about a year a go to my 95 RS.
Old May 2, 2006 | 10:13 AM
Thanks for the replys guys, but im woundering if i have to change motor mounts or can i use the same ones?
turbodelsol3
Feb 28, 2007 12:13 PM
supermanvick
Feb 16, 2006 02:58 PM
eyece
Nov 10, 2005 05:28 AM
DA6righthand
Jan 8, 2004 10:19 PM
AznInvasion
Sep 12, 2003 06:19 PM
