hood doesnt shut.
Old May 1, 2006 | 03:07 PM
EGhatch33's Avatar
Default hood doesnt shut.
my stock radiator is keeping my hood from closing. the top bracket on it hits the hood when it closes. has anyone experienced this? the previous owner would just slam it shut so it has 3 small dents, but i'm trying to think what i could do to fix it.
Old May 1, 2006 | 03:52 PM
s2000june's Avatar
Default Re: hood doesnt shut. (EGhatch33)
they prolly had to replace it or got a junk yard rad.. And didnt put it back in all the way.. i would take it back out and make sure its all the way in place like the bushings arent getting stuck or maybe its the wrong rad.. either way you can mod it.. If it still dont latch the latch could be bent from slamming it over time
trust me i know.. i screwed up mine trying to run a g2 ls rad and it was too high
Old May 1, 2006 | 04:15 PM
EGhatch33's Avatar
Default Re: hood doesnt shut. (civicrida3)
yup mine's too high. i was just messing around w/ it some more, took out the bushings and now it's way more normal. not what it should be tho. any more ideas?
Old May 1, 2006 | 04:17 PM
EGhatch33's Avatar
bump in hopes to fix my hood
Old May 1, 2006 | 04:33 PM
MightyHyman's Avatar
bump, gl guy
Old May 1, 2006 | 04:36 PM
ekcivic9's Avatar
is the rad support bent?
if the bracket is hitting, that means its not flush with the rest of the car.
can you take a picture?
Old May 1, 2006 | 05:18 PM
Syndacate's Avatar
1 of 3 things..
1. wrong radiator/rad support
2. not installed properly
3. wrong hood/aftermarket hood, etc.
Take pictures, try to locate the problem - trust me, it doesn't come stock not able to close...
Old May 1, 2006 | 05:52 PM
EGhatch33's Avatar
Default Re: (Syndacate)
1 of 3 things..
1. wrong radiator/rad support- can't be the wrong support... i havent changed it...radiator was ordered for my exact engine (got a new radiator)
2. not installed properly- multiple people have looked at it
3. wrong hood/aftermarket hood, etc.- hood has never been changed. oem.
it just seems to be too tall. the old radiator had the same problem. like i said before the problem was there before i bought the car.
i'll work on gettin pics
Old May 1, 2006 | 06:02 PM
s2000june's Avatar
Default Re: (EGhatch33)
cut the bushings dude.. theres lots of things you can do.. aslong as that **** is tight in there and not moving.. Your good is it still not latching ? the latch is fucked cause theres nothing else that would keep it from latching if its not hitting anything
Old May 1, 2006 | 06:16 PM
EGhatch33's Avatar
Default Re: (civicrida3)
no more bushings.. sits lower, latches... but still hitting hood.
Old May 1, 2006 | 06:25 PM
s2000june's Avatar
beats me then.. doest make since it hits something has 2 be bent.. or something is off.. get that rad lower.. mod it..
Old May 1, 2006 | 06:37 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGhatch33 &raquo;</TD></TR><TR><TD CLASS="quote">1 of 3 things..
i'll work on gettin pics</TD></TR></TABLE>
u said it was for the same engine...is it for the same body?
hate to say it but it's one of those 3....it has to be, cars jsut don't come with hoods that won't close
Which could lead to #4 possibility, car was hit and something wasn't bent right (which sorta goes with the fact that it's not installed properly (#2), maybe ur latch is too far down, I'm not sure, but something is wrong, and it's under one of those 3 things I listed..
Old May 1, 2006 | 08:11 PM
v-tecleta's Avatar
same thing with my del sol and i just found out that the last owner bumped the cars front end ruining the alignment so the hood wont shut coz the hook from the hood and latch doesnt lock in place so what i did i cut the hook and took the latch off and just got hood pins even though i dont like it. looks better than what it was..
avpethe
Jul 11, 2013 03:01 PM
shoklid
11
Jul 2, 2009 07:10 PM
2fast4udude
Mar 5, 2006 03:43 PM
Bodman
Jul 21, 2003 12:00 PM
.nate
May 18, 2002 06:13 PM
